7 members (MickeyP, David Bush, kades51, Gdads51, cmayna, Donf, 3800GUY), 90 guests, and 1 robot.
Topics128,049
Posts1,055,702
#1597495 02/10/2026 4:31 AM
B Online: Content
Anyone have minimum thickness specs for a GMC 270 flywheel? I've looked in both the 51 and 57 GMC Maintenance Manuals. No mention in either of resurfacing flywheels at all.
I've never seen specifications for anything like that, even in more modern vehicles. But flywheels are pretty thick and unless you're whittling it down to less than 1/4" thickness, I doubt it will make a difference.
H Online: Content
On some of the round track cars, we would routinely machine 1/8" or more off the clutch disc side of a small block Chevy V8 flywheel, then turn it around on the lathe and take a bunch off the engine side. That was done to lighten the rotating mass to allow the engine to accelerate quicker off the turns, and give faster compression braking at the end of the straightaway. I don't recall ever breaking one of those flywheels, even at 7K+ RPM.
I found this in the 46 and 47 Maintenance Manuals.
B Online: Content
Thank you sir.
I don't know why I missed it, but the same paragraph is in the 1951 GMC Maintenance Manual.
Given that the is no spec for minimum thickness, the only thing to worry about is was there material ground off in the past.
