Trying to remove the heater control panel on my '60 C10. Had it out back in the '80s but like many things I can't recall the trick. Have screws & braces remove. Can tip it in at the bottom but not far enough as the top hits the underside of the dash. Not finding anything in 1960 service manual. I should get a FAM but don't know if that would help with removal.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022
BC - Below are screengrabs from the 1960-66 FAM and some web pics of an NOS control on ebay. It looks like you have to push the unit straight back into the dash cavity, probably might help to remove the glove box for an extra hand on the back side, then once clear of the dash opening angle it down and out under the dash.
The actuator cables may provide a lot of resistance to pushing the unit back, and defroster ducts might affect pushing it into the recess too.
Hope this helps.
Edit note: Don't forget to unplug the controls lamp/socket at the top rear of the unit. Maybe best done again by removing the glove box insert.
~ Dan 1951 Chevy 3 window 3100 Follow this story in the DITY Gallery "My Grandpa Carl's Truck and How it Became Mine" 1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
