7 members (Nick in Manitou, 66flea, Cletus1950, Hotrod Lincoln, 2-Ton, Jay R, TooMany2count),
333
7
Mod | | | Forums66 Topics128,158 Posts1,057,025 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 10 New Guy | | New Guy Joined: Aug 2007 Posts: 10 | Anybody tried this impact ratchet? -------------------------------------------------------------------------------- http://www.mytoolstore.com/ke/kw1175.html I had wondered why no one had made one of these, and just found this one by accident. It appears to work more like an impact wrench than a conventional ratchet. It has a higher max torque rating than most ratchets and, as they say in the description, it should have less of a tendancy to slam your fingers into surrounding hard, metal parts. My regular ratchet would have less of a tendancy to do that if it didn't have such a "hair trigger". Has anyone replaced the spring on the actuating lever with a heavier one? Brady | | | | | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | Have not tried it, and for the price tag on it I will never be trying it either. I don't see the need (for me) for a 3/8 drive impact air ratchet. I'll stick with my 3/8 air ratchet for under $50.00 and a can of Blaster or Gibbs to get a bolt started if its frozen up.I have an 18 inch 3/8 breaker bar for those nasty bolts. If I was back in the body shop working I might think about it for the sake of saving time, but around the house/shop I don't think so. 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | | | | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | Oh, By the way, Welcome Brady.  1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | WVBrady,
Welcome to the Stovebolt. It's interesting you should mention the trigger/spring setup on the 3/8" drive air ratchet. I just repaired one the other day. In my case, it wasn't the spring tension that gave it the 'all or nothing' actuation, it was the design of the valve that throttles the air to make the tool function.
I used the same spring, but replaced the shaped plastic valve with a hardened steel ball. It seals perfectly and is much more controllable...no more hair trigger.
Stuart | | | | | Joined: Aug 2007 Posts: 10 New Guy | | New Guy Joined: Aug 2007 Posts: 10 | Thanks for the replies and the welcome. "I have an 18 inch 3/8 breaker bar for those nasty bolts." I would be more interested in one because of the reduced reaction torque than for the increased max torque. I can usually break a bolt loose by depressing the lever and just using the wrench as a normal wrench. Then when it comes loose, the ratchet spins it off. What I don't like is when it cracks my knuckles into something hard, when I do not have it well braced (or when the hair trigger catches me by surprise). "replaced the shaped plastic valve with a hardened steel ball" That sounds like the same one I have. I think it is a Sunex (it's up at my Mom's right now) that I bought from M-Wards about 25 years ago. I also put a steel ball in mine, but I had no idea what the plastic piece looked like. It had degenerated into a formless blob, and the ratchet wouldn't turn off. I didn't notice any improvement in control, but I didn't have a collection to different size ball bearings to experiment with. I bought a box of 100 (anyone need 99 ball bearings? Better make that 98; I might need to replace it some day)  . | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That's not really anything new to the market. I've got an Ingersoll Rand air ratchet that I got about 13 years ago that's works the exact same way, and cost much less, too. Snap-On has one out, too. Don't know the cost, though. Personal opinion, if you need more than 50-75 ft/lbs to break it loose, you might as well break out the conventional impact gun.
Bill Burmeister | | | | | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 |
"It ain't a truck if you can't hose out the cab."
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Now don't cha cringe at this, it's definatly not for the pro but as a conversation piece, thats gonna lay in the tool box out in the garage it's certainly worth the thirty bucks. I do have one, hardly ever use it but when I do it works just fine, so far that is. http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=47214 Denny G
Denny G Sandwich, IL
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | That looks like a fine piece of equip.I purchased one about 8 years ago for around $45.Like some of the others around here I dont use it that often,but when I do it has worked so far.If your gonna use it a lot its probably worth the $200. | | | | | Joined: Sep 2007 Posts: 11 Apprentice | | Apprentice Joined: Sep 2007 Posts: 11 | that looks like a pretty cool air ratchet, I'll be asking snap-on and matco if they make one like it. I'm more likely to buy one through them just because of the warranty and convenience. 200 bucks doesn't seem to pricey, considering I recently spent over $100.00 on a 1/4 inch fine tooth locking flex ratchet (not air powered) from matco.
it's not a brick, it's cruise control.
