| | | Forums66 Topics128,261 Posts1,058,344 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2022 Posts: 176 'Bolter | | 'Bolter Joined: Dec 2022 Posts: 176 | Help me understand. pleas
How do you search old posts. You know over 10 years old. When I go to advanced search and enter a criteria over 10 years I get this.
"The specified date range is too wide. The maximum date range you can search with is 10 years"
Is it simply that posts ove 10 year do not exist? Are they Archived? Are they right there and Im looking in the wrong place?
or am I just searching all wrong.
this place is like the lost dutchman mine, full of treasure, Im just having trouble finding it.
Rock49 aka C-Rodg work in progress 1956 Chevy 3100 261 engine | | | | | Joined: Sep 2009 Posts: 6,199 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,199 | Rock - Are you using this link to begin your Search??? That link does not specify any range of history unless you specify it in the query box. For example, if you want to search for past threads on 261 engines, just type in 261 to start. It will list some ad links and then jump into the most pertinent threads based on the 261 in the titles of the threads. If you want more detail or limits to the search, just add definition to your search terms. IE; 261 in a Task Force truck. You will get slightly different responses depending on what you ask for, so it helps to refine/redefine your queries. If whats in that first page of links isn't catching what you seek, there is a "More" button at the bottom of the page to continue down the list of the query findings. Hope this helps.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Jul 2000 Posts: 2,213 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,213 | If you are using the "older than" option, make sure you have blanked out the "newer than" boxes.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Dec 2022 Posts: 176 'Bolter | | 'Bolter Joined: Dec 2022 Posts: 176 | Gdads51 Thank you. looks like im over thinking it. I go to the magnifiying glass at the top of the forum, then advanceed forum search. The date range is in the advanced area. I start with a broad search term then refine following the guidelines in the how to sticky on this forum. I gues I should just leave the date range empty.
Thanks fore pointing out the "more" button I did not see it.
Rock49 aka C-Rodg work in progress 1956 Chevy 3100 261 engine | | | | | Joined: Sep 2009 Posts: 6,199 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,199 | That magnifying glass search is different than the actual "Search the Site" link tool. The magnifying glass search I believe has built in UBB limitations that are not found in the "Search the Site" tool.
You can find the link to "Search the Site" in the left margin boxes using most computer and tablet applications, but to see it on a phone, you need to turn your phone sideways to get the whole page to display the left margin things. Otherwise look at the top of each forum page header as there is a "Search" link to tap on to take you to the search feature.
