5 members (UtahYork, Gdads51, Cletus1950, Hotrod Lincoln, MickeyP), 81 guests, and 3 robots.
Topics128,150
Posts1,056,985
Members48,460
About a week ago I picked up this here battery tester. Well dumb me here, not quite sure how to use it. It doesn't seem to open up far enough to go from post to post? Hopefully a picture shows up?
The battery posts on my 1956 Cadillac are very close together on one end of a 20 inch long battery. Maybe that was a typical design of batteries prior to the mid 1950s? That tester would easily contact both posts.
You'll probably have to use a jumper on modern batteries.
1950 Chevrolet 3100 (Ol' Roy)
Those were used to check each cell on older batteries that had tar over the tops. Notice that the gauge range only goes up to 2 V, which is the nominal voltage of a single lead-acid cell. The points would jab thru the tar and contact the lead connectors underneath. Not usable on newer batteries with plastic tops unless you destroy the plastic covering. The tar would heal back over the lead where the holes were made.
Used one of those as a much younger version of myself.
BC
1960 C60 pasture art
Former Workshop Owner
Cool conversation piece. I’ve never seen one of those before.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
H Online: Content
That tool was designed to SELL batteries, not test them. Show a customer a very low voltage reading on a low or discharged battery, then sell him a new one. Then recharge the trade-in (all it needed anyway) and sell it as a "rebuilt" battery at half the price of a new one! In the days of 6 volt batteries that ran low frequently because of poor charging system operation, it was a very common practice among unscrupulous retailers!
I still have one of those somewhere. It is probably about 70 years old. It load tests each cell individually back when the straps between cells were exposed. During the 1970's the straps between cells were no longer exposed. Probably in the mid 1970's I purchased a carbon pile load tester put the entire battery under load to test. Several years ago I purchased a very expensive battery diagnostic system. I am disappointed in the tester. I still prefer to use the carbon pile load tester on group 31 batteries. And the carbon pile tester uses the same principle as the load tester show. I used the cell tester like the one shown 70 years ago. And it would still trust it to load test a cell.
Moderated by  MNSmith
