6 members (Otto Skorzeny, Gdads51, 3B, 55shaker, Woodcmiami, 1 invisible), 262 guests, and 2 robots.
Topics128,086
Posts1,056,098
Members48,434
#1596250 01/18/2026 5:28 PM
I finally have all the creases, bends, rust and cracks repaired on the cab completed and ready for final primer and paint. The frame, suspension, steering, brakes, etc is completely gone through, renewed cleaned up and painted. I’d like to paint the cab and marry the two in place again. Then I could start putting things back together and clear some room in my shop. Windshield, steering column, wiring, seats, brake, clutch pedals, bleed the brakes, rear glass, headliner and trim, etc. My question is paint purchase. What is shelf life if I were to buy a gallon and only use part for the cab, doghouse and headlights and rest down the road? Fenders running boards black so no worries. Body will be boatswain blue, single stage probably from Jim Carter. Hood, sides, doors and bed still in progress and I’m slow… gallon or a quart? And would a quart safely do the cab?
Larry
Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
37 GC #1596252 01/18/2026 5:59 PM
The paint I bought from Jim Carter sat unopened for about 4 years till I started painting. Then it was another year or so when I finished up. The tech sheet said 1 year, but I didn't have any real issues. I may have used a little more reducer at the end, but everything turned out OK. I used a gallon and a quart, and I think a quart might be enough for the cab. 4 quarts will cost you significantly more than a single gallon, but if bought at the same time, would probably be fine color match wise and extend your shelf life.
37 GC #1596254 01/18/2026 6:06 PM
Thanks. Though I’d like to be finished tomorrow, I know better and I work when I want and not if I want, anal and slow, but I’d like to continue bouncing around in projects so I don’t get burned out doing, say body work only. Putting some things back together motivates me and so many things on the shelves put on a finished cab would be great.
Larry
37 GC #1596301 01/19/2026 2:33 PM
AD Addict & Tinkerer
The activator is usually the problem when it comes to short shelf life, especially if opened.
Phil
Project Journals
Stovebolt Gallery Forum
37 GC #1596312 01/19/2026 5:51 PM
What Phil said about the activator or hardener. The ALK-200 that Jim Carter sells doesn't need hardener, but it can be used. The trouble is that finding the appropriate hardener in smaller than quart quantities is very hard. I found some 1/2 pint cans on eBay, which is enough for a gallon of paint.
37 GC #1596319 01/19/2026 9:02 PM
Buy a gallon or more, and immediately break it down into new quart cans. Seal them tightly. Air space in a partial can is what makes paint go stale- - - - -the less air, the longer the shelf life will be. Getting the entire batch mixed at one time will minimize the chance of not getting a good color match with smaller quantities mixed in separate batches.
37 GC #1596341 01/20/2026 1:14 PM
back yard wrench turner
I found these and plan to use them on my next project.
paint storage bags
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
37 GC #1596381 01/20/2026 9:51 PM
Has anyone used nitrogen gas in half full/empty paint cans?
~Charley
1954 Chevy 3100 with 235
“Bud”
Follow along in the DITY
1963 Chevy half ton stepside short box 230
1954 GMC 3 ton 302
And several more Chevy camper and work trucks 1979 1987 1996
37 GC #1596400 01/21/2026 1:56 AM
I was wondering about using argon/co2 welding gas. Not sure if it'd be smart, but no O, or h2o.
RonR
RonR
1970 340 Duster
1964 CJ5
RonR
I always (almost) flood the can with 100% argon through a crack just before closing the can. I don't know if it does anything but it makes me feel smart. Maybe someday I'll appear in one of those "old school guy taught me this" videos. It has to be better than my midwestern air.
37 GC #1597733 02/13/2026 9:59 PM
I've put a piece of Saran wrap into the can so it's touching the top of the paint, then put the lid on with the edges of the wrap sticking out, That way there's no open air touching the paint.
