1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#1596127 01/16/2026 8:47 PM
8
nothing beats a try but a failure
8 Offline
Did the 55.1 3600 come with 1 or 2 tail lights? Also, how did the tag get lite?
1955.1 3600 5 window 4 speed all original except the 410 gears.
In the Project Journal
87GN #1596128 01/16/2026 9:30 PM
One taillight on driver's side standard. It has a white lens incorporated into the design to illuminate the license plate.
1950 Chevrolet 3100 (Ol' Roy)
87GN #1596130 01/16/2026 9:50 PM
8
8 Offline
Been trying to find one, could you help me find on?
87GN #1596137 01/16/2026 11:53 PM
Try any of the following companies:
Jim Carter www.oldchevytrucks.com
Classic Industries www.classicindustries.com
LMC Truck www.lmctruck.com
NPD www.npdlink.com
The Filling Station www.fillingstation.com
87GN #1596140 01/17/2026 12:53 AM
I just looked and the web sites seem to not list the 54 you have to scroll to find them as they don’t just appear .if your truck has a step side bed then Jim Carter has them for a decent price .there are led lights that show they fit up to the late 50,s so I think the task Force trucks with the step side are the same but do double check .I noticed even Amazon has a similar looking light .anyway here is what I think is a fair deal from Jim Carter that I found, others may have a similar price but you would have to search for them .Also took screenshots of the bracket available ,can also get chrome. I don’t know what the difference is in the more expensive ones .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
87GN #1596146 01/17/2026 3:45 AM
87GN - Otto is correct that the original truck standard equipment came with the one tail light assembly for the drivers side. The license plate on your 1955.1 would have been illuminated by a light that's parts of a separate license plate bracket (not attached with the left brake light assembly which mounts to the bedside stake pocket), mounted to the left side of the rear cross sill for 1954-59 stepside trucks. There was a Right Hand "passenger side" rear light assembly (GM#986907) offered as an "accessory" that truck buyer could order and have installed on the truck by the dealer. Also available was a dealer installed accessory turn signal kit, if one was desired.
I know that a single taillight assembly is period correct, but in today's driving having two (or more) taillights is really a necessity for safety sake.
Many of our regular vendors offer both the drivers and passenger side taillight assemblies, as well as reproduction brackets for both sides.
The Jim Carter offered light assembly mentioned by Kevinski can be found as LG157 - same fixture for the right side, so if you want that order two (2).
The Jim Carter offers taillight brackets as LG149 (left) and LG163 (right). Note that the LG149 left bracket does not include the license plate bracket. To get the separate license plate bracket with license plate light, that's Jim Carter part LG283.
As mentioned above, there are lots of other vendors that offer these pieces, some fancier (chrome, etc.) and more expensive, but I think these Jim Carter pieces will fill the need.
Let us know how things turn out. It would be a great update to your Project Journal. smile
~ Dan
1951 Chevy 3 window 3100
87GN #1596190 01/17/2026 9:55 PM
8
8 Offline
Thank you all for your help. Look forward to showing my choice in my project journal.
