1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#1595652 01/08/2026 2:00 PM
My GM coe did not have an outer door seal,
it was either gone due to age or never had one.
The truck has an an inner door frame track to run
a seal around the door. Is it still supposed to have
the outer seal around the outside edge of the door as well like all other models of trucks?
Short answer according to the 1947-54 Chevrolet Truck FAM is yes. Doors get the same glue on rubber formed seal around the entire COE door perimeter as shown in the FAM extract pic below.
I'd suggest you read this reply to the older thread Door Seals / Weatherstrip Installation - Correct ? and view the linked still active video. It should prove helpful. The only real difference with COE doors, that I can tell from the FAM, is the lower door access panel has an overhanging flange along the bottom that looks to be part of the panel itself, where the regular truck cab doors have a separate metal strip that protects the bottom edge of the door weatherstrip from getting snagged/torn.
~ Dan
1951 Chevy 3 window 3100
That makes sense, that picture is great to see as well. I watched Dr J’s video last night, he explains it very well. Thank you very much
Moderated by  ndkid275, Phak1
