3 members (55shaker, Wally / Montana, Steelonsteel), 143 guests, and 4 robots.
Topics128,201
Posts1,057,276
Members48,466
Howdy and Merry Christmas!
Just curious. Have any of you burb or panel owners ever found a way to mount, in a very secure fashion, the upper shoulder mount bolt for a set of 3 pt belts? I don't see a way to get into or behind the pillar column?? I have the Classic Parts mount plate but if I can't get it behind the sheet metal..... Hum???? Mounting it to the outside surface with 4 hi tensile sheet metal screws??? Still doesn't seem totally safe?? Mig weld the edges of the mount plate to the sheet metal? I don't know. Appreciate your wise input. Thank you all!!
Just from a standpoint of strength, welding the mount plate to the sheet metal would be stronger than using sheet metal screws. But welding a thicker piece of metal to the thinner sheet metal is difficult. Possibly if the mount plate can be shaped to fit closely to the sheet metal, brazing it in place would be easier and likely just as strong. Way less chance of burning through the sheet metal.
No. I went with lap belts
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
Leo Offline
Moderator
Moderator
I installed 3 point belts into my 1953 panel. I happened to have some 4"x4" x 3/16th plates with half inch holes in the center. I taped it to the end of a wooden yardstick and positioned it behind the sheet metal (there is a bit of room) They have been there for many years, never tested in a crash. The belts came from early 90s Chevy pickup.
Leo's method would be better with the plates behind the sheet metal. I did a similar thing on my 3100 using a kit from one of the seat belt vendors made specifically for AD trucks. The headliner has to be out to get the reinforcing plates behind the sheet metal.
Maddoggee1959 - Not sure if it may be of some help, but many Bolters have purchased and installed 3-point seat belts from Juliano's Hot Rod Parts to upgrade their rides for safety.
Here's a link to Juliano's 3-point seatbelt install in a 1956 Chevy TF Truck that might prove helpful with your question. Not sure if a TF Burb or Panel has the same way to reach up and inside the cab space to install the anchor plate as the truck in the instructions, but maybe a source for further ideas to get there. wink
Let us know what you end up doing as it could help other Bolters in the future. smile
~ Dan
1951 Chevy 3 window 3100
It would also be possible to cut a narrow slot in the sheet metal of the door post, insert a backing plate for the belt anchor, attach the anchor with pop rivets, and MIG weld the slot closed.
Just want to say thank you to all you fellas that have provided me with numerous options for my TF 3 point belt program. I'll let everyone know how it turns out!! Happy New Year!
