6 members (Gray_Ghost, IHPWR, TexasA&M48Truck, KCMongo, TUTS 59, 1 invisible), 107 guests, and 2 robots.
Topics128,034
Posts1,055,540
Members48,425
#1593457 12/04/2025 2:33 PM
FMM
Offline
Where can I find the "M" shaped spring for the lower door hinge on my 48 COE project? It's different than the standard cab upper hinge springs that are available. Thanks
Check out THIS THREAD.
Maybe Super55 can help you out.
FMM
Offline
I decided to try to make one using the one in the passenger door hinge as a guide, without removing it. Just estimated the bends and it came out pretty good..I found an old coil spring and heated it red to uncoil enough, then made the bends heating it where needed. I installed it and with it clamped in a vice, it snapped open perfectly but when I tried putting it into the cab hole, the bends were too long and so I had to reheat and make some adjustments..it should hold the door open just fine.
