10 members (tclederman, Ponchogl, Otto Skorzeny, 55shaker, Bill Hanlon, Rusty Heaps, 1955 1 Series, BC59, 3800GUY, 1 invisible),
141
0
Mod | | | Forums66 Topics128,104 Posts1,056,201 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2020 Posts: 274 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 274 | Hi all, I have my ‘50 3100 torn down to a bare boxed frame, and am thinking about front and rear end combinations. I had a friend swap an independent jag rear end into a ‘56 3100 years ago, and he says “go for the Jag rear end over a Ford 9”. I’m looking for opinions and info. A forum search came up with “400 answers”, none of which had anything to do with a Jag swap. Any help would be appreciated. | | | | | Joined: Sep 2009 Posts: 5,886 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,886 | Paul - Here's two related old threads (2011) that should be some good info for your consideration. Lots of info and a pretty much full build picture stash on flicker in the second thread. Happy reading. Jaguar suspension swap in a '50 GMCProject XJ-12 PU V12 * * Note: This one is involving a 1940 3/4 ton, but should have a lot of great relevant ideas for your thought process.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Dec 2020 Posts: 274 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 274 | | | | | | Joined: Feb 2004 Posts: 29,799 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,799 | There's another option, one that might be newer, and less expensive than the Jag. Toyota Supra has a differential mounted to a subframe, with swing axles and independent suspension. it's basically a somewhat downsized version of the Jag, and those units can survive HP outputs in the 1000+ range from the beaned-up Supra DOHC six. I've got one stashed away in my "one of these days" project list, which will go behind a 390 CID Cadillac V8 in an Excalibur roadster. Jerry
| | | | | Joined: Sep 2008 Posts: 293 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 293 | Flat Out Engineering has kits for front and rear Corvette suspensions. Less exotic than a Jag, but easier to find, cheaper... And there is a kit...
'57 Chevy Suburban; '70 Chevy Impala.
| | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | Think about parts availability. Especially for any old or major components that aren't available anymore. Whereas, these days, the Ford 9 inch is on par with the Chevy small block in the 70's, 80's and 90's. Or the LS today. Everybody makes plenty of parts for them. I thought about adding a Jag rear end in one of my projects. Firstly, they were difficult to find and when I did, the seller thought they had gold. | | | | | Joined: Feb 2004 Posts: 29,799 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,799 | For instance- - - -here's a current listing on Ebay: www.ebay.com/itm/266611482591?Jerry
| | | | | Joined: Dec 2020 Posts: 274 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 274 | I saw that one Jerry. There is a complete Jag rear out of an ‘86 XJ6 that the guy is asking $400 for. The cradle looks a lot easier to deal with than the whole sub-frame assembly of the Supra. On another note, I saw an ‘86 Supra for sale for parts for $500. Motor and transmission are already gone. | | | | | Joined: Feb 2004 Posts: 29,799 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,799 | That price is pretty outrageous, but it illustrates a suspension system, brakes, and final drive that somebody else has already done the engineering on to make it work well. I've got the same basic setup that I acquired for a lot better price- - - - -free! I'll just modify the rear frame area of the Excalibur that was also gifted to me to make the rear section fit. The front will be a M-II setup that I purchased for $200.00. Jerry
| | | | | Joined: Aug 2010 Posts: 601 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 601 | You could probably find the whole '80s Jaguar on FB Marketplace for $800 these days.. I see them from time to time. They were a bummer to keep running back when all those British electrics were new. Add 35 years of leaking seals and attendant corrosion, and you've got cheap projects aplenty that "ran when parked.."
| | | | | Joined: Dec 2020 Posts: 274 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 274 | Thank you all for the information/encouragement. I brought home the rear end yesterday, and will be going through all of the applicable posts after hoisting it out of the back of my truck | | | | | Joined: Mar 2009 Posts: 14 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 14 | I haven't been on the forum in a while, so my reply is a bit late. I installed the front and rear suspension from an 85/86 XJS (I bought1 of each) and lowered the truck around 4 inches. It rides really nice, and power steering is a wonderful thing! I'm happy to share details.
Mike
1953 3600 350/700R4
| | | | | Joined: Feb 2004 Posts: 29,799 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,799 | Another good source of a frame mounted differential and independent rear axles is a Toyota Supra. They're capable of handling 600+ horsepower, and they're not as hard to find or as expensive as Jag parts. Jerry
| | | | | Joined: Aug 2010 Posts: 601 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 601 | I have no doubt that a Supra rear end is a lot more modern than the Jag, but what ratios of ring and pinion do Toyota offer for it? Or, is it compatible with other Aisin third members for which there are different ratios available? At least on the Jag, it's compatible with Spicer rear gears, of which there are plenty available.
| | | | | Joined: Feb 2004 Posts: 29,799 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,799 | Toyota offers at least a couple of ratios- - - -depending on whether the car has a turbo or not. I believe one of them is a 4.30:1. There's also a 3.73. I'll be using a Supra rearend behind a Cadillac 390 engine and a turbo 350 or 400 trans in an Excalibur roadster I'm building. Maybe a 4L60 overdrive if I can find a stand alone control box. I have all three transmissions on hand. Jerry
