1 members (classicchevs),
101
Mod | | | Forums66 Topics128,093 Posts1,056,474 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2025 Posts: 2 Moderated | | Moderated Joined: Sep 2025 Posts: 2 | Is there a way to convert factory front wheel bearing to roller bearings While keeping the 8 lug wheels? | | | | | Joined: Sep 2009 Posts: 5,964 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,964 | First off Welcome to Stovebolt!  Since your topic falls into the realm of the Driveline Forum I've moved your post over there for further conversation and help. Others should be along soon to provide some helpful info.  Once again, Welcome!
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | On this forum some time ago, a "bearing man" said ball bearings had less contact with the race and he thought they were better in our application.
I've always thought the roller bearings must be cheaper to make. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Oct 2021 Posts: 6,879 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,879 | My '56 Cadillac has huge ball bearing wheel bearings. The car weighs 5000 lbs. 200,000 miles and they're still going strong. There is no reason to switch to roller bearings.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Jan 2022 Posts: 2,475 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,475 | . IF you decide to convert to roller bearings ...
New Departure # 9726 (inner) and 9725 (outer) were original equipment. These were known by their GM part numbers 909726 and 909725. New Departure (among others) also made a direct replacement roller version of these bearings numbered 909726R and 909725R.
Note that the adjustment procedure for roller bearings is very much different from ball bearings.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Nov 2025 Posts: 13 'Bolter | | 'Bolter Joined: Nov 2025 Posts: 13 | We bought a 51 3100 that had been converted to the roller bearings. I would not have done that but will leave them in there. We have 4 Chevys with the ball bearings and never had a problem, it might that I do maintenance occasionally. | | | | | Joined: Sep 2009 Posts: 5,964 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,964 | . IF you decide to convert to roller bearings ...
Note that the adjustment procedure for roller bearings is very much different from ball bearings. Bill - Are these bearings correct for the 3600??? He’s asking about converting his 3600, not a 3100.
| | | | | Joined: Jan 2022 Posts: 2,475 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,475 | Yes, those are right for a GMC 150 (3/4 ton) and I'd bet your life that 3/4 ton Chevys use the same.
| | | | | Joined: Sep 2025 Posts: 2 Moderated | | Moderated Joined: Sep 2025 Posts: 2 | Thank you for all the help with fining the wheel bearings | | | | | Joined: Sep 2009 Posts: 5,964 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,964 | Yes, those are right for a GMC 150 (3/4 ton) and I'd bet your life that 3/4 ton Chevys use the same. Thanks Bill. You are right that the ball bearing numbered units mentioned are listed for both Chevy and GMC 3/4 tons. I did a pretty thorough web search and found none of the "roller style" replacement bearings (inner or outer) to fit 3/4 ton Chevy's or GMC's currently available. In fact I couldn't find a single cross reference to any roller style bearings for these applications. Just lots of the original style "ball bearing" units which seem to be pretty widely available. Hope Bristol's Tree S is okay with using original style bearings as there doesn't seem to be an alternative out there.
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | Back 60 to 70 years ago, we had more failures with roller bearings than ball bearings. Even with the sorry grease we had in those days, ball bearings ran almost forever. If I needed wheel bearings, I would find some used ones. With today's grease they will run forever. | | | | | Joined: Jan 2022 Posts: 197 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 197 | Is there a way to convert factory front wheel bearing to roller bearings While keeping the 8 lug wheels? If you have deep pockets. 909046R909045R | | | | | Joined: Sep 2009 Posts: 5,964 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,964 | Thanks for finding those and posting jimgmc!  Having "deep pockets" is an understatement at those prices IMHO though. I'd have to stick with tried and proven original ball bearing sets. A person could buy a whole bunch of those for what would be handed over for these.
| | | | | Joined: Oct 2021 Posts: 6,879 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,879 | I don't need any wheel bearings but I had to look. $300 each! That's absolutely ridiculous!
| | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | There was kit available at one time NLA these days. I found the part numbers but that was a dead end. You can' t use dimension bearings because the inner one needs something for the seal to run on. The ball bearings are spendy enough already, $60+ last I looked. IIRC they also fit Buicks from the 50s. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | |
