3 members (Wayne67vert, Peggy M, klhansen), 53 guests, and 2 robots.
Topics128,154
Posts1,056,851
Members48,456
(Moderator, feel free to move this)
My brother Jack has a '71 Chevy 1/2 ton long bed with we think is the original 350 V8. It has been in his wife's family since new. As far as we know, the engine has never been opened up.
We pulled the oil pan today so we could stop oil leaks at the pan and the rear seal. After I left, Jack pulled the oil pump and found this mess in the sump screen. Plastic bits and pieces.
I know Pontiac used plastic/nylon on their cam sprockets in the late 60's/early 70's. Did Chevy do the same?
Bill - Unfortunately the answer is yes. frown Original 1971 Chevrolet 350 cam gears (36 tooth) for all applications is listed as GM# 3896960 according to the below extract (1st pic) from an October 1970 Chevy Master Parts Book covering the 1971 model year.
A web check came up with an NOS GM 3896960 Camshaft Timing Gear being offered on evilbay. The 2nd and 3rd pics below are screengrabs from that ad showing the overall gear and close up with the specified part number shown.
Looks like it's time to fully open up Jack's 350. dang
PS - I found that Chevy also used a nylon type cam gear even in similar year Big Blocks under GM# 3856356. big_eek
~ Dan
1951 Chevy 3 window 3100
O Online: Content
All the GM makes used the nylon gears, including Cadillac. Even Ford and Mopar used them in some engines.
When they deteriorate, the white plastic shavings clog up the oil pump.
Seemed like a good idea at the time , I guess. Nice and quiet.
1950 Chevrolet 3100 (Ol' Roy)
The truck was bought new by my brother's father-in-law in '71. My guess is that at some point before it was given to my brother's wife 25+ years ago the plastic teeth failed and someone replaced the gear (and maybe the whole timing set) without removing the pan and cleaning out the debris. The truck is still running okay, but only has an oil pressure idiot light, so no telling actual pressure.
