3 members (chemanic, Otto Skorzeny, Mike Roache), 76 guests, and 2 robots.
Topics128,135
Posts1,056,418
Members48,441
#1591107 11/02/2025 11:02 PM
Been running a couple (HI/LOW) 6 volt clamshell horns for the past 30+ years on my 12 volt system. No El Problems, at all. Then a couple days ago, I suddenly lost the low horn and then a day or two later the HI horn started making crazy zapping sounds each time I hit the button. Time to figure out why. Was very concerned that the horns were dying on me. I noticed the horn relay was very crunchy looking and was wondering if maybe it was not sending a correct signal to the horns. NAPA auto had one in stock for a whopping $20. Dove into swapping the new relay in today and OMG. Both horns are now tooting again. The truck is smiling once again......
Craig
cmayna #1591108 11/02/2025 11:11 PM
Craig - It's grand when you can diagnose and fix your problem this easily! thumbs_up What relay part number did you use from NAPA? headscratch
~ Dan
1951 Chevy 3 window 3100
cmayna #1591113 11/02/2025 11:21 PM
I'll bet those 6 volt horns are LOUD
cmayna #1591114 11/02/2025 11:32 PM
Dan,
It is NAPA #HR101SB and yes Bill, VERY loud, but I only quickly tap the button twice. TOOT TOOT. No real long hold downs.
Craig
cmayna #1591116 11/02/2025 11:58 PM
Thanks Craig. Enjoy your TOOT TOOT! thumbs_up
~ Dan
cmayna #1591147 11/03/2025 4:21 AM
When I went to 12V years ago, I wired my horns in series. Worked great for years except now they don't. I'll have to look at them in the Spring.
Like old time Christmas tree lights, when one quits they all quit.
