11 members (GMCJammer51, Steveoreno, 4tttt8, Jay R, Joe H, dt235sd, Peggy M, 55shaker, FAST55, 1955 1 Series, Waveski), 95 guests, and 5 robots.
Topics128,180
Posts1,057,164
Members48,465
U
U Offline
Just finishing up my bed and was wondering about the holes at the cab end. When I took the bed apart I noticed holes in the center of the wood planks, but don't remember seeing any bolts. Are you supposed to add these bolts or is the bed fine as is?
Bolt holes for the bed wood?
~ John in Utah
Here We Go
Follow in his DITY Bay
Maybe this photo will help? Note that this bed was a kit from Mar-K, so my assumption is they had the layout correct.
Looks like those bolts hold the front panel to the wood bed .My 54 has bolts that close to the end but they also go through the metal strips.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
U
U Offline
OK - I can see how they would hold in the front panel and keep it from bowing towards the cab. Thanks Kevin!
~ John in Utah
Here We Go
On the AD series trucks, the front bed panel bends toward the rear and then down, and bolts to the front cross sill. It looks like the earlier beds didn't have the front panel bolted to the front cross-sill. You can see the bolt holes in the vertical flange of the front panel in the attached picture. The cross-sill isn't bolted in yet.
[on edit] This is probably true only for beds with angled top bed sides per kevinski's observation (below) on his '54. Mine is a '51.
Last edited by klhansen; 10/27/2025 10:47 PM. Reason: corrected an oops and added a note about year range
The 54 at least mine is different only bends towards the rear does not attach to the cross member
"The Journey"
Follow in the DITY
Very likely the 54 & 55 beds with the flat top bed sides rather than angled top were different.
U
U Offline
I added the those end bolts. Thanks for all the input Guys!
~ John in Utah
Here We Go
As long as the offset mirrors the hole on the other side, I'd put one in. It'll look fine.
1950 Chevrolet 3100 (Ol' Roy)
U
U Offline
Well, the offset is the same and I do have the two extra bolts. Might as well I guess. I just added it to tomorrows To-Do list. 😀
~ John in Utah
Here We Go
U
U Offline
OK - I installed those last two carriage bolts on the outside boards. They're not centered on the boards and offsets look the same on each side, so it looks fine. Thanks Otto for giving me a little push.😁
Installed carriage bolts at front of bed frame.
~ John in Utah
Here We Go
