Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (cmayna, baldeagle), 51 guests, and 2 robots.
Topics128,006
Posts1,055,268
Members48,418
Page 2 of 6 1 2 3 4 5 6
AD Addict & Tinkerer
Loved your 12,500 mile trip visiting friends and family, national parks and last but most importantly, truck parts! Got a camper and inclosed trailer in the process. You are not only a talented restoration artist but a schemer to boot. Great job!
Phil
Project Journals
Stovebolt Gallery Forum
That is neat to see the sign still in place .🪒
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
LOL! Yeah the National Parks bit was needed to get the wife on board. We also visited the Botanical Garden in Wichita. She's a big gardener.
July 2019
Dug out the heater and tested and painted the core. This one was painted a hammered green color, which seemed a bit rare. I have tried matching the color, but without much success, so will eventually paint the housing with the usual Rustoleum Hammered Bronze color that’s a pretty close match to the more common bronze colored heaters. Also arranged for a sandblaster to come to the house and sandblast the cab. He set up a tent and went after it, spending nearly all day. I also managed to track down a nice used air compressor, a 60 gallon vertical 5 HP unit
Green heater housing
Cab set up for blasting
Blaster suited up and ready to start blasting
Blasting completed
Top View of blasted cab
Bottom of blasted cab
Air Compressor Installed
August - September 2019
After spending some time working on my boat (complete rewiring), got into welding patch panels on the cab. Started with the bottom of the passenger side A-pillar, and replacing the rocker panel.
Passenger side A-Pillar bottom patch
Passenger side rocker panel removed
Scrap metal
Passenger side rocker panel in place
December 2019
Restored the gauge cluster. Used decals from Jim Carter, along with a replacement glass and bezel.
Disassembling gauge cluster
Back of gauge cluster
Restored Gauge Cluster
January 2020
Worked on straightening the front bumper splash apron that I drug out of that wrecking yard in Nebraska. Someone apparently wrapped a chain around it and the bumper and crushed it in the center. I welded some tabs on it and tried stretching it back out with some all-thread and wound up building a fixture to stretch it back into shape. I finished it off by flattening it with the press I built to straighten the ribs on the running boards. Also worked on installing the passenger side inner cab corner and floor patching around the battery opening. Installed the rocker on the passenger side. Fit and installed the passenger side cab corner.
Apron stretching
Apron Stretching fixture
Finish straightening with press
Fitting inner cab corner
Patching around battery opening
Fitting passenger side rocker panel
Fitting passenger side cab corner
Passenger side cab corner ready for welding
Passenger side cab corner welding
Bottom of cab corner spot welded
February 2020
Worked on patching the passenger side of the firewall, fitting inner cowl, inner-to outer cowl panel and outer cowl panel. Fitting passenger side floor.
Passenger side firewall patching
Fitting passenger side inner cowl and inner-to-outer cowl piece - gap-osis
Fitting top of inner-to-outer cowl piece
Fitting outer cowl panel - still a long way to go
Fitting passenger side inner cowl panel
Fitting floor/toe panel patch
Slicing and dicing floor patch panel
March 2020
More fitting of passenger side cowl & floor, including reinforcement of transmission opening. Welding passenger side floor in place, fitting and welding flange on toeboard panel.
Fitting floor, rocker and inner cowl panel
More fitting of inner cowl panel - getting closer
Front of inner cowl panel fitted - working on the back fit to A-pillar
A little heat applied to help the fit.
Floor panel tacked in place
Fitting transmission opening reinforcement
More tacking floor/toe board joints
Transmission opening reinforcement spot welded in place
"Wing" tab welded in place at floor/toe board bend for reinforcement
fitting and welding flange on side of floor panel
Still March 2020 (it was a busy month)
Welding in passenger side floor support. Fitting driver side floor patch panel with recess. Fitting driver side rocker panel & inner cab corner. Welding floor patch in place. Trimming floor patch. Fitting driver side floor panel. Fitting seat riser patch.
Fitting right side cab support - Located from front of dash to bolt hole.
Passenger side cab floor support welded in place
Fitting driver side rocker and floor panel with underseat recess
Inner cab corner, rocker and floor patch panel in place
Welding driver side floor patch in place
Fitting driver side floor/toeboard patch panel
Fitting seat riser patch in place
Your metalwork skills and tenacity to get it right is impressive. Great work and thanks for the great detailed narrative. It will no doubt help guide other ‘Bolters thru their issues.
Phil
Project Journals
Thanks, Phil. As of that latest date, the bulk of the metalwork was done. Then got on to the tedious part of getting the exterior parts ready for paint. eek Still working on more posts running thru all the pics. smile
That hammered green is nice .I have the same round heater that is the same colour and another spare that was grey .When I refurbished my recirculating heater I was looking for the hammered paint and realized mine was a silver originally. I think the heaters may have been a different color for chev/gmc .
"The Journey"
Follow in the DITY
Kevinski, I recall another bolter had a green heater as well, back when I was looking into it. Maybe it's a Canadian thing, as this truck may have been driven up thru Canada and they had the heater installed en-route to Alaska. This heater definitely had a "Chevrolet" sticker on it. I sure wish there was a close match in green hammered paint. If so, I'd put it back the way it came to me (less the rust of course.) wink
KL ,
You inspired me to get after my leaky Heater Core. I was dreading taking it back out of my truck. But last summer when it started to leak i install pex tubing ball valves in line of the heater hoses and put it on the back burner. It took me less than five minutes to remove it from the truck. dang probably just was putting it off because of past experiences with other vehicles and heater boxes being such a PITA.
Luckily I had another heater box that came with my truck and that one tested good with no leaks. When taking apart the unit I had in the truck I also discovered mine to be a shade of blue green on the back side and inside the box that you speak of. Shined up nice with rubbing compound.
Headed to my local Lowes. They had quite an assortment of hammered colored paints. Gonna see what I can find.
Jeff
1964 Chevrolet K10 Fleetside
"A Kid's First Truck"
Follow in the DITY
1951 Chevrolet 3100
Follow his build in the Project Journals
1969 Chevrolet Camaro Convertible | 2020 Chevrolet Silverado | 3500 Duramax | 2021 GMC Sierra Denali
USAF Veteran 1983-1987 | PSP retired 1990- 2012
Jeff, If you find a paint that matches, I'd sure like to know what you find. thumbs_up
No luck. Nothing even close. I bought matte hammered black. Looks gray.
Jeff
Follow in the DITY
1951 Chevrolet 3100
A little different logo but same green
"The Journey"
Follow in the DITY
I saw that Rustoleum has hammered clear coat. That might be an option if the base color could be matched to the color of the heater.
April 2020
Spent some time patching seat adjuster mounting point. It got beat up pretty severely with chunks cracked out. I welded in a patch to secure the seat adjuster. Checked the fit of the driver’s side floor/toeboard patch and inner cowl patch. As you can see there’s a fairly large gap that needs to be fixed on installation.
Beat up seat riser mounting point
Patched up
Major gap-osis at the inner cowl panel to driver's floor
May 2020
Working on installation of driver’s side floor/toeboard patch panel and inner cowl panel.
Checking fit of floor and inner cowl panels
Fitting driver's side floor and inner cowl panel
Massaging inner cowl to fit floor - heat to help
Fitting floor panel
Welding in homebuilt patch at toe-board/firewall junction
Floor panel welding
Fitting transmission opening reinforcement to toeboard
Spot welded transmission opening support
Cab support welded in
June 2020
Working on driver’s side inner cowl panel and inner-to-outer cowl panel. Trimming and fitting outer cowl panel.
Starting on cutting and fitting inner-to-outer panel
Outer cowl trimmed away for replacing
More whacking on inner-to-outer cowl piece
Still more cutting and fitting of inner-to-outer
Fitting to inner cowl panel
Checking fit on top to outer cowl panel
Front view of the inner-to-outer
Locating and drilling for plug welds
June 2020 (another busy month)
Working on doors. Removing run channel and recording clip locations (wound up using screws in place of clips.) Weld repair on loose door latch and building up worn areas. Working out crease on passenger door. Welding in outer cowl panel.
Welding loose door latch
Fixing crease in bottom of passenger door
Welding top of cowl at hood area
July 2020
Welding in driver’s side outer cowl panel. Primer on inner fenders, radiator support, aprons, doors, and LF fender.. Final paint on inner fenders, radiator support and radiator aprons.
Finishing up cowl welding
Primer on inner fenders, radiator support and aprons
Primer on doors, LF fender
outside of doors and fender primered
Ding in passenger door - shows up on primer
Lower passenger door crease - nearly gone
Another shot of primer on outside of doors and fender
Final paint on inner fenders and radiator aprons
August 2020
Converting parking lights to dual filament for turn signals. Straightening minor tweaks in the frame with a ball joint press.
Original Parking light (upper) & modified with dual filament bulb (lower)
Dual filament socket pigtails
Tacking sockets to brackets
Modified parking light housing
Frame straightening
Frame straightening
September 2020
Working on passenger side inner cowl panel, inner-to-outer cowl panel, and outer cowl panel.
Using a punch to install hole in inner cowl panel
Fitting inner cowl to toeboard
Fitting inner-to-outer cowl
Drilling inner cowl for plug welding
Welding inner cowl panel in place
Welding outer cowl panel
September 2020 (yet another busy month)
Patching windlace tracks. Welding holes in cab for the mickey mouse ear turn signals. Completed cab floor and cowl.. Primer coat on completed cab. Undercoated cab floor.
Welding windlace track patch
Patching mickey mouse turn signal hole - plug in place
Patching mickey mouse turn signal hole - finished weld
Welding on cab completed
Primer coat on cab - in the sun to help drying
Undercoating on cab floor
September 2020 (yep, still busy)
Patching rusted lower inner door panels. Patch panels from Jim Carter.
Cutting out rust. Markings for windlace retainer screw holes.
Fitting patch panel
Trimming for patch panel
Welding in patch panel
Fitting patch panel on driver's door
Driver's door patch panel welded in
Weld cleaned up and skimmed with JB Weld
October 2020
Primer on lower door panel patches from last month. Removed the engine from chassis. Patching rusted spots on frame. Dismantling chassis.
Primer on door bottom patches
U-joint - do you think it's any good?
Pulling engine & tranny from chassis
Patch on frame hump where wet wood had sat
Patch at LR bumper mount
Patches on radiator mount holes on front crossmember
Pressing out spring shackle bushinigs
Frame stripped down
October 2020 (another busy month)
I picked up a free 1954 3100 chassis that netted me a couple wheels, and a few other miscellaneous parts. The front springs were totally trashed, with the rear eyes broken and the berlin wrap on the second leaf the only thing holding the springs to the rear hanger. Someone had driven it that way for quite a while. Got my frame stripped down and tucked away for the winter. Started hammer and dolly work on the nose of hood.
Free '54 chassis
SCARY spring mount
Right side spring mount just as SCARY
Frame tucked away for the winter
Frame tucked away for winter
Hood nose - working out dents
November 2020
Repairing door latches. I built up worn spots with weld metal and ground them down. Used copper strips to protect areas that didn't need weld metal spatter on them. The doors on the truck had been sagged for years and the wear on the striker parts showed. I was able to get them back in usable condition. Also fabricated new rear lower shock mounts. Had a spring shop bend the bars and drill for me. The new shocks came with the mounts which I welded to the bars.
As found
Wear spots latch
Copper strip to control weld
Weld buildup on striker
Striker dressed back to profile
Prep with copper strips for safety catch buildup
Safety catch buildup
Safety catch ground back to shape
Replacement lower rear shock mounts - upper was what was on the truck.
December 2020
Set up a zinc plating arrangement and plated some parts including hood hinges, hood latch spring, & door lock retainer. Hood hinge springs didn't work so well, but they‘re clean. Got some replacement door hinge faceplates and worked on rebuilding the door hinges.
Hood hing with a bit of rust on the edge
Plating bath with hood latch spring and door lock retainer being zinc plated
Hood latch spring wearing new zinc plating
Hood support springs in plating bath
Plating results on hood support springs - didn't take very well
Door hinge Faceplates - old vs new
Door hinge with new faceplate attached and painted.
Drilled out hinge arm with bushings for oversize pins
January 2021
Recast rubber in the transmission support. Used a torch to melt out the rubber, and made some molds to support the pieces in the proper position and used Simple Resin Enduro-Soft 2-part polyurethane. It turned out that wasn’t up to the task, so redid it with Enduro-Flex, which is advertised for use in poly bushings.
Transmission mount in original condition - oil soaked rubber
Melting out rubber from transmission support
Plywood form in place for pouring 2 part polyurethane
Bottom side plywood form
Forms clamped in place and ready for pouring
2-part polyurethane poured in place
Forms stripped off
February 2021
More zinc plating. Hood supports (plated half at a time as my bucket wouldn't submerge the whole part- worked OK) , Miscellaneous clips and screws. Door Latch before & after
Hood support arm -1/2 plated
Miscellaneous clips and screws plated and bagged for future use
Hood support arms in plating bath
Hood support arm plated
Hood support arm with spring reinstalled
Door latch before plating
Door latch after plating
March 2021
Repairing steering arm balls. They were severely worn and undercut. I got new balls that were press-in style and peened over the opposite end to secure them.
Severely worn steering arm ball
Another view of worn ball
Pressing in replacement steering arm ball
April 2021
Zinc plating hood latch. Retrieved the frame from sandblaster and got it on a rotisserie for painting. Primered and painted the frame, axles, and miscellaneous frame parts.
Hood latch going in the plating bath
Hood latch with plating completed
Unloading frame onto the rotisserie. Wife helping out.
Frame on rotisserie
Primer on frame, rear and front axles
Another shot of primered chassis parts
Chassis parts in semi-gloss black
Another view of painted chassis parts
Primered miscellaneous parts - running board brackets, fender supports, etc.
May 2021
Rebuillding rear axle mount pivots. Used some PVC pipe couplings for moulds. First try was with Enduro-Soft by Simple Resins. As it turned out it wasn’t durable enough and I had to redo it with Enduro-Flex, a harder polyurethane resin. Replaced front axle kingpins, but had a little oops on one side (I coulda been one of those negative camber ricer guys that seem to be the rage now. wink ) Fixed that and got the front springs mounted to the frame. Also bolted on running board brackets, battery tray, etc. after finish painting them. Bolted the front axle under the frame.
Disassembled axle pivot bushing with rings for re-casting
Setup for casting. Angle and clamp for support. Sleeve centered by eyeball.
Resin poured in place. Rings sealed with RTV.
Another shot of completed pour - a little leakage
Completed pivot with forms stripped off.
Front springs and running board brackets on the frame
OOPS!
Much better! LOL
Front axle mounted under frame
May 2021 (continued)
Got the rear axle mounted to the frame and found that the mount pivots didn’t hold up. Bolted on replacement running board brackets, making the frame essentially complete (except for fixing the rear axle pivots.) Found that the rear axle bump stops I got from Jim Carter didn’t line up with the holes in the frame, but got them bolted on anyway.
Rear axle pivots smooshed out - bummer!
The other side, too. :-(
Completed frame (except engine and tranny)
Jim Carter rear axle bump stop
Frame holes for axle bump stop
Forced them in place.
June 2021
Back to working on the cab. The right side cowl panel weld needed to be pulled out a bit, so used a pin welder and got that close to the right spot. Also pulled out a couple dents above the rear window using the pin welder. Got that profile pretty well cleaned up. Found a rattle can paint color that matched the rear grille bars and brackets - Rustoleum Canvas White a darn close match. Shot primer on the hood, grille pieces, window frames, etc. After a couple issues with the resin setting up too quick got the rear axle pivots recast.
Cowl patch with weld pins
Cowl weld pulled out flat
Deep dents above rear window
Dents pulled out and finished
Test sprayout of Rustoleum Canvas White on grille support
Rustoleum Canvas White rattle can
Primer on hood, grille bars, etc.
Primer on hood, grille bars, etc.- other side
Failed polyurethane setup - set up before able to pour
Completed axle support bushings
July 2021
Ordered some copper-nickel brake line and fabricated new brake lines. Installed all new master and wheel cylinders and hoses. Drug the engine out from under its cover and went after it with the pressure washer. Pulled the transmission and bell housing off and found the rear core plug nearly rusted thru and clogged with crud. Got it cleaned out and got the engine on the stand.
Right front brake lines
Brake lines at division block at engine mount crossmember
Right front brake lines and new hose
Master cylinder and main brake line
Right rear brake lines and hose to axle
Left rear brake line
Crusty rusty bell housing
Leaky core plug
SLUDGE!!
Moderated by  Phak1
