4 members (Wally / Montana, Otto Skorzeny, baldeagle, joe apple), 72 guests, and 0 robots.
Topics128,078
Posts1,055,940
Members48,430
I have a manual for my year truck, but not the new motor. Need the torque sequence and torque increments for the main caps for a '59 235.
Thanks!
55-2 Truck Shop Manual says 100-110 ft lb. No specific sequence noted. The 59 Truck Shop Manual Supplement doesn't change that
1 Offline
I would just go center toward front then rear in three increments. 60, 80 and then 100. JMO
Be sure the bolt threads and the underside of the bolt heads are oiled. Just motor oil- - - -if an anti-seize compound like Never-Seez is used, reduce the spec by 10%.
The main bearing caps are not like a head. No need to jump around. Each cap is independent. But creeping up on the max isn't a bad idea, but just on the two bolts on each cap (or 4 on the rear main.)
Thanks gentlemen. Just wanted to make sure there wasn't a specific sequence.
It can be easy to hydraulic lock the threads if the oiling is not done correctly, that goes for any oiled thread applications. Material can be cracked from it, I have seen it happen.
