| | | Forums66 Topics128,212 Posts1,057,463 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2022 Posts: 116 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 116 | Not sure what way to go here. I am planning on running a set of 461 g.m. cylinder heads which has a 1.50" round exhaust port. Now, my exhaust manifolds have a stock 1.312" rectangular shape. I could see it being the other around, so what would be my best option here? Get the Die grinder out? Thank you! | | | | | Joined: Jan 2022 Posts: 116 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 116 | To me it looks like the exhaust pressure coming out of the cylinder head would be partially blocked if the exhaust manifold ports are smaller, thus loosing power.. This is the way I bought the cylinder heads with round ports, some 50 years ago.. | | | | | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | Yes, you'll need to blend the exhaust manifold ports to match the head ports. Even a relatively abrupt cone shape in the manifold to prevent turbulence as the exhaust gases enter it is better than creating a step. Those round ports are intended to be used on a race-only engine with headers of the same size and shape as the ports. As I've been preaching for years, doing race engine stuff on a street engine makes no sense, and usually ends up with a very temperamental engine which only develops increased power at RPM ranges and road speeds that makes the vehicle a ticket magnet. Cops and judges love hotrodders! Jerry
| | | | | Joined: Jan 2022 Posts: 116 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 116 | Thanks Jerry, out where I live cop's are generally dealing with more serious stuff then us small hotrodders as we generally go up to a 1000 ft. track about 10 miles from here just to have a little fun.. | | | | | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | Put four turns and a chert gravel surface, and 20 cars on that track, and you can do some real racing. LOL! Jerry
| | | | | Joined: Jan 2022 Posts: 116 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 116 | Yeah you know Jerry were not to far from where you run that frozen whale up over the Grapevine some time ago.. Were still just a bunch of Ol country farm boys still alive having fun and of course having the Good Lord with us.. Jerry your the Man and I can honestly tell you most will agree. Thanks..
