Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (Tony292, baldeagle), 28 guests, and 3 robots.
Topics128,003
Posts1,055,244
Members48,418
#1587309 09/13/2025 9:19 PM
What is the difference between the single acting and double acting lever shocks, what would my 3/4 ton have? I look at new shock bushings from various vendors and they refer to either the single or double acting.
Thanks, Tom
The difference between single-action and double-action shocks primarily relates to how they control suspension movement:
Single-Action Shocks
These shocks control movement only in one direction, usually the rebound (extension) of the suspension. The shock provides resistance mainly when the suspension extends after a bump. They use lever arm or lever-type designs common in older trucks like the 1946 Chevy. Compression (when the wheel moves up) is controlled by the springs rather than the shock. Most stock shocks on 1946 Chevy 3/4-ton trucks were single-action lever arm shocks. They tend to provide a softer ride but less control over suspension during compression.
Double-Action Shocks
These shocks provide damping during both compression (bumping) and rebound (extension) of the suspension. They offer more control and improved stability because they resist suspension movement in both directions.
Modern double-action shocks usually have internal valving to provide this dual resistance.
Double-Action Shocks were not original equipment on 1946 Chevy trucks but can be installed as upgrades for better handling and ride quality. Don't know if a double action level type shock exists. Switching to a double action tube type shock would most likely require modification to mount.
Work is the curse of the drinking class
U
U Offline
I have double-action shocks front and rear on my '46. I didn't know the difference since these came with the truck.
~ John in Utah
Here We Go
Follow in his DITY Bay
