Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
6 members (49choptop, TUTS 59, BLUEMEANIE, DES57, Peggy M, Waveski), 531 guests, and 1 robot.
Topics126,777
Posts1,039,282
Members48,100
Most Online2,175
Jul 21st, 2025
#1588063 09/21/2025 11:46 PM
Need an oil pan for my 1954 235 full pressure stove bolt.
tlietha - Your 1954 235 can use an oil pan from Chevy 1953 Passenger cars with Powerglide (automatic) transmission 235's, ALL 1954 235's (both truck and passenger car regardless of transmission), and 1955 1st Series Commercial and Utility truck 235 engines as they all use the same pan (GM# 3701602). See the screenshot below from a 1962 Chevy Master Parts Book.
Here's an ebay offering for a 1953-55 235 pan that needs repair for a pretty high asking price. The main reason I posted this is so you can use the good pictures to help when searching for the correct replacement pan.
In reading your post about the damage to your oil pan HERE, I'm wondering how much your pan is damaged/dented???
It may be that your dented pan is easier to repair than one of the many currently offered "used" and "needing repairs" pans I saw in my web search.
Best of luck with your search! thumbs_up
~ Dan
1951 Chevy 3 window 3100
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 1.055s Queries: 15 (0.042s) Memory: 0.5958 MB (Peak: 0.6351 MB) Data Comp: Zlib Server Time: 2025-09-22 17:07:17 UTC
Valid HTML 5 and Valid CSS
