Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
3 members (Peggy M, 52Carl, Gdads51), 600 guests, and 1 robot.
Topics126,778
Posts1,039,258
Members48,100
Most Online2,175
Jul 21st, 2025
#1588024 09/21/2025 3:28 PM
V
VEW
Offline
V Offline
Need it for my 41, which has TF front and rear and 17-1/2” wheels. I only have 3 of them, of course.
Looks like 10” diameter. Thanks
~ Victor
1957 3100 - moved on
VEW #1588032 09/21/2025 4:44 PM
K Online: Content
Look like ones from the 60,s
kevinski
1954 GMC 9300
VEW #1588060 09/21/2025 10:57 PM
Just an FYI that the ones in KEVINSKI's reply from Classic Industries, Part# CT26720, are listed as only fitting 1964-66 Chevy 15" C10 wheels.
The Classic's caps are shown as 10-3/4" inside diameter and height of 2-1/2", which seems similar to Victor's hub cap diameter dimensions, but there must be a reason why they say they will only fit 15" rims.
Victor can you give more dimension info, like the actual inner diameter and height from cap rim to top center of the cap? It might help finding a source for your missing hub cap. wink
~ Dan
1951 Chevy 3 window 3100
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.048s Queries: 16 (0.046s) Memory: 0.5993 MB (Peak: 0.6502 MB) Data Comp: Zlib Server Time: 2025-09-21 23:08:21 UTC
Valid HTML 5 and Valid CSS
