Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
2 members (TPR57C, Bills Auto Works), 525 guests, and 1 robot.
Topics126,777
Posts1,039,270
Members48,100
Most Online2,175
Jul 21st, 2025
I’m having a bit of a challenge sourcing an oil seal for the output shaft on my 3 speed manual transmission (1955 235 engine, Apache 3100). I think I found one on eBay but worry about compatibility.
Anyone have any suggestions? Is there a specific brand and part number that I should search for? An online store (called Summit Racing but they didn’t have)?
Is there a way to find which specific transmission I have? I know which casting numbers to use for the block and head but no clue where to start on the transmission.
Welcome to Stovebolt.
From what I find in the 1929-1957 Parts manual, you have two options (highlighted on the attached.) A good parts store can either use the dimensions and the GM PN to cross over to a current manufacturer's number.
NAPA's website says their Part #: NOS 22340 fits. It matches the dimensions in the first seal I highlighted.
National 9613S Oil Seal
~ BD.
You won't find me in an old folks home
Thank you @klhansen and @Guitplayer!
9613S is available at Auto Zone for about $5
Also fits 350 TH, Powerglide, and overdrive transmissions.
Fred
Thanks rfs56trk. Seal acquired!
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.036s Queries: 15 (0.033s) Memory: 0.6146 MB (Peak: 0.6802 MB) Data Comp: Zlib Server Time: 2025-09-22 10:51:40 UTC
Valid HTML 5 and Valid CSS
