The cover that came with my truck does not fit. My truck is a 1953 half ton, with a 235 engine and original 3 speed tranny. The part or parts I'm looking for are the sheet metal inspection cover(s).
Mike Burns 1940 Chev 1/2 ton 1953 Chev 1/2 ton 1950 Studebaker Starlight Coupe 1947 Indian Chief 1943 Indian 741
Mike, you should post a pic of your bellhousing and the cover that doesn't fit so we know what NOT to send you. I may have what you need if the bellhousing is the same as my '51.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
You're right. I no longer have the cover that didn't fit. I think it probably hit the crossmember nearby. Here are pics of the bellhousing and surrounding area.
