Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
7 members (arustycars639, Hugh63c10, KEVINSKI, Gdads51, Lonnie, 52Carl, Peggy M), 573 guests, and 1 robot.
Topics126,778
Posts1,039,258
Members48,100
Most Online2,175
Jul 21st, 2025
The cover that came with my truck does not fit. My truck is a 1953 half ton, with a 235 engine and original 3 speed tranny. The part or parts I'm looking for are the sheet metal inspection cover(s).
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
Mike, you should post a pic of your bellhousing and the cover that doesn't fit so we know what NOT to send you. I may have what you need if the bellhousing is the same as my '51.
You're right. I no longer have the cover that didn't fit. I think it probably hit the crossmember nearby. Here are pics of the bellhousing and surrounding area.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1947 Indian Chief
1943 Indian 741
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 1.597s Queries: 16 (0.030s) Memory: 0.6006 MB (Peak: 0.6499 MB) Data Comp: Zlib Server Time: 2025-09-21 23:14:07 UTC
Valid HTML 5 and Valid CSS
