6 members (JW51, KEVINSKI, Joe H, WingWright, 3800GUY, Gdads51), 121 guests, and 1 robot.
Topics128,110
Posts1,056,255
Members48,437
#1587446 09/15/2025 8:23 PM
JD1
Offline
Hi.
I have a 1951 3100. I have 16" x 6.5" bias tires on it.
The rims are 6 lug.
I do not have a spare.
I have a few junkyards around me. If I wanted to pickup a rim for a spare, what size would I be looking for?
JD
1951 Chevy 3100 1/2 ton (1957 235, 4 speed, 411 rear)
JD1 #1587449 09/15/2025 8:31 PM
O Online: Content
I believe the original rims are 16" x 4.5"
1950 Chevrolet 3100 (Ol' Roy)
Correct. Later 16" rims (55.2 and up) were 5" wide. They usually had only 3 hub cap clips instead of 6. The 5" wide wheels were used with 6.50-16 tires. If 6.00-16 tires came on the truck, it would still have had 4.5" wide rims. The 4.5" wide rims were phased out (along with 6.00-16 tires) for '56 model trucks. Later Vehicle Info Kits dropped wheel size data for some reason. But they do not include 6.00-16 tires on any models.
klhansen #1587528 09/16/2025 4:13 PM
JD1
Offline
Kevin,
I am not sure if the rims are original to my 51. My rims have 6 hub cap clips.
I have 16" x 6.5" tires on it, so that would mean the rims are 16"x5" correct?
Thank you.
JD1 #1587531 09/16/2025 4:39 PM
If they have 6 hub cap clips, they're likely 4.5" wide. I'm pretty sure your current 6.50-16 tires weren't installed at the factory. The will fit on the narrower 4.5" rims. That's what I have on my 3100.
When GM went to the 5" wide rims (a better fit for wider tires) they reduced the number of hub cap clips to 3, but there may be 6 clip holes, and possibly someone installed more hub cap clips, but I doubt someone went to that much trouble.
JD1 #1587535 09/16/2025 4:54 PM
O Online: Content
I got 3 clips and 6 clips mixed up in my mind. Yes. The earlier rims - 4.5" wide - have 6 clips. The later rims have 3 clips.
JD1 #1587576 09/17/2025 12:50 AM
JD1
Offline
Thank you guys.
JD1 #1592610 11/23/2025 8:05 PM
Just picked up a 16x4.5 with 3 clips to go along with my other 4.5’s with 6 clips. I added 3 more. Now the clips don’t match. Original 3 are fatter, but so…
Larry
Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
JD1 #1592615 11/23/2025 8:29 PM
37 GC If your truck is an art deco series, as opposed to an AD, it would have come with 4" wide wheels. Early AD wheels (47 and 48, I believe) also used 4" wide wheels. But the wider wheels should fit fine.
JD1 #1593084 11/30/2025 1:57 AM
Yep, I was aware they should be 4”. When I brought the truck home it had one 4”, two 4.5, and one 5”. I’m using 6.50 16’s on 4.5’s and they look pretty good. I’ll use the 4” for a spare, it’s not in great shape. All are 4 slot. When were the 8 slot wheels used?
Larry
JD1 #1593268 12/02/2025 3:55 AM
8 slots came on 1937 and 1938 trucks.
