Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
3 members (GMCJammer51, Pre '68 Dave, 1 invisible), 566 guests, and 1 robot.
Topics126,777
Posts1,039,270
Members48,100
Most Online2,175
Jul 21st, 2025
After axle disassembly to install new inner seals, It was discovered that the driver side rezeppa joint has a cracked crown (?) that holds the balls in place. I am guessing that the passenger side is not any better.
Does anyone know of 2x 3/4 ton joints that i can buy to replace them?
Milt
1958 3600 rezeppa joint
1958 Chevrolet 3600 NAPCO 4x4 Apache
"Calvin"
Assuming Chevy used the same axle in '58 and using GMC Master Parts Book as a reference, that is going to be a hard part to find. They do not break down the individual pieces of the joint by part number. 3/4 ton would use the FH-035 axle. S, T, X in the listing represent 1958-9, 1957 and 1956. The good news (???) is that it appears the 1/2 ton part (FH-030 axle) uses the same part.
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 1.618s Queries: 16 (0.050s) Memory: 0.5944 MB (Peak: 0.6403 MB) Data Comp: Zlib Server Time: 2025-09-22 12:41:05 UTC
Valid HTML 5 and Valid CSS
