4 members (32Fordpuchoptop, 55shaker, TUTS 59, 1 invisible), 70 guests, and 0 robots.
Topics128,078
Posts1,055,940
Members48,430
#1587240 09/12/2025 11:45 PM
My C60's SM420 transmission had a factory input shaft seal, now it has a modern neoprene seal. However it's the two ton input shaft and it's a '65, so maybe they treated those better. I just wish it had the backup light fitting/switch. That seems to have debuted in '67.
Last edited by Dusty53; 09/15/2025 6:17 PM. Reason: change Title to refelect post question
Novak will drill, tap and install a backup light on your SM420 top cover for a price.
Click here
Last edited by Dusty53; 09/15/2025 6:16 PM. Reason: change Title to refelect post question
I always wondered if I could do that, it doesn't seem hugely complex. Maybe they could sell me the switch and I could figure the rest out myself.
PapaDisco #1587275 09/13/2025 12:28 PM
O Online: Content
I've never owned a vehicle that had backup lights that actually illuminated anything well enough to assist reversing at night.
1950 Chevrolet 3100 (Ol' Roy)
PapaDisco #1587315 09/13/2025 10:39 PM
If you have a receiver hitch this is bright.
BC
1960 C60 pasture art
PapaDisco #1587317 09/13/2025 10:57 PM
O Online: Content
Wow, that's bright.
I was referring to factory installed reverse lights. None of them do anything to improve visibility at night while reversing.
What do you do if you want to install a hitch? Does that light just pull out?
Tronman #1587380 09/14/2025 10:02 PM
Insomniac
Insomniac
The switch is common. I broke mine and the local auto parts store had it. ISTR someone installing their own switch in a pre-1967 transmission - maybe search the forums.
Backup lights are a great safety feature; not just for night driving. Last week, I was in a parking lot getting ready to back up when I saw the backup lights on the car behind me come on. I waited for the guy to leave.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
PapaDisco #1587388 09/14/2025 11:05 PM
I installed a Motorcraft switch SW-1835 into my extra stored SM-420 gearbox back in 2004. It was great to have that extra gearbox for such projects.
Here's a link to a thread I started way back in '04.
https://www.stovebolt.com/ubbthread...ght-switch-project-completed#Post1322705
Craig
Tronman #1587764 09/18/2025 10:18 PM
On the early SM 420s there was a lever arm that attached to the shift handle that depressed a simple 2-wire push button switch to operate backup lights. It would be a very easy project to fabricate one of those from parts available at the local hardware store. I've used a pair of fog/driving lights attached to a rear bumper to make VERY efficient backup lights. A push button wired into that circuit was also effective at getting tailgaters to back off a little!
