| | | Forums66 Topics128,089 Posts1,056,139 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2014 Posts: 3,686 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,686 | Can a new one be tapped in from the front? Or does the timing cover have to come off?
Understand that I need to inspect the balance and sleeve it if necessary.
1951 3100
| | | | | Joined: Sep 2009 Posts: 5,872 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,872 | Nathan - Yes, you can tap in a new front crank seal into the timing cover without removing the cover from the engine. Yes, you have to remove the balancer and knowing our old engines, a sleeve will likely be needed and is a good idea to have one ready at hand.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Feb 2004 Posts: 29,798 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,798 | The same speedy sleeve that fits a small block V8 also works on a stovebolt balancer. The better quality repair sleeve kits include a small vial of red LocTite to bond the sleeve to the balancer snout firmly. Jerry
| | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | A side note. Remove the radiator first. Notice I did not say, " I recommend that you remove the radiator." I am Telling y'all to remove the radiator first. No sugar. I dang near ruined a rare Desert Cooler radiator tryin to cut corners. I got lucky because I know one of the few radiator repair gurus still alive.
| | | | | Joined: Jan 2014 Posts: 3,686 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,686 | A side note. Remove the radiator first. Notice I did not say, " I recommend that you remove the radiator." I am Telling y'all to remove the radiator first. No sugar. I dang near ruined a rare Desert Cooler radiator tryin to cut corners. I got lucky because I know one of the few radiator repair gurus still alive. 10-4!
1951 3100
| | | | | Joined: Jan 2014 Posts: 3,686 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,686 | New cover seal is in. New motor mount is under the engine. Not an easy job. Don’t want to do it again any time soon.
1) Repair sleeve is on the balancer. The install tool bottoms out when the flange is probably 1/8 inch from the balancer face. I guess that’s the way it’s supposed to be? It doesn’t seem to be a tear-away flange like some others I’ve used.
If it drove it on much further, it wouldn’t cover the groove anyway.
2) I don’t have time or the tools to drill/tap the crank. It’s going to get hammered on. Would it be a bad idea to heat it to make it slide on easier?
1951 3100
| | | | | Joined: May 2015 Posts: 11,065 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,065 | Stick the balancer in the oven for a while at 250-300F, then it should go on pretty easily. Maybe wait till the little lady is away before using her oven. We'd like to have you around for a while.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2014 Posts: 3,686 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,686 | I might just use the pellet grill. I will catch some grief for that, too. But much less.
1951 3100
| | | | | Joined: Jan 2014 Posts: 3,686 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,686 | My plan was to do the rear mounts at the same time. That’s gonna have to wait. Getting to the driver side mount bolts looks like a real treat.
1951 3100
| | | | | Joined: Feb 2004 Posts: 29,798 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,798 | Be sure to drive a hardwood wedge between the clutch cover and the back of the bellhousing, to avoid damaging the crankshaft thrust bearing while you're using a BFH on that balancer. Just drop the dust cover under the flywheel and wedge the crankshaft full forward. Jerry
| | | | | Joined: Oct 2019 Posts: 347 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 347 | Using the snout tool Jerry mentioned makes tapping the crankshaft bolt a ten-minute job. I have one if you need it. | | | | | Joined: Jan 2014 Posts: 3,686 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,686 | I might take you up on that someday. I got it done with the heat and best method. I didn’t think to block the rear like Jerry suggested. Truck ran fine yesterday on a long drive. Hope I didn’t damage it.
By the way, I let the balancer heat to roughly 180 degrees on the grill. That was over an hour at 250 grill temp. That is not hot enough for easy installation.
1951 3100
| | | | | Joined: Oct 2019 Posts: 347 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 347 | If you want to use it, just pay the shipping both ways and you can borrow it. It takes about 5 minutes once you get open access to the snout. It has the snout tool, drill bit and tap. | | |
