4 members (greenie-reddy, Jon G, cmayna, dt235sd), 26 guests, and 4 robots.
Topics128,021
Posts1,055,372
Members48,420
#1586731 09/06/2025 10:44 AM
Much importance is placed on the disk which is pressed into the block 1” from water pump opening. I suspect that the disk has been missing for many years in my 1935 Chev 1 1/2 ton 207CID. Due to corrosion in water jacket, there isn’t much left to press new disk into. I see no option other than JB weld to hold it in place.
1935 Chev 207
Punch #1586747 09/06/2025 4:57 PM
Punch - I'm at a bit of a loss on what hole you are mentioning in relation to the water pump opening??? headscratch Your water pump hole is clearly visible, but I'm not seeing a hole needing a "disk" (core plug seal) in your photo. Please provide a wider view picture and if possible an indicator on the "hole" in question.
~ Dan
1951 Chevy 3 window 3100
Punch #1586765 09/06/2025 9:24 PM
From the Filling Station website.
1935 WATER PUMP BAFFLE PLATE
Item ID: AF-254
Make: Chevrolet
This water pump baffle plate is installed in the block behind the water pump and is necessary for proper water pump efficiency. Many times this piece is rusted out or missing. Check it each time the water pump is removed! Fits all 1935 Chevrolet cars & trucks. Replaces GM# 837611
This part fits most 1935 Chevrolet Cars and Trucks.; exceptions may apply. Please read the complete description to see if this part fits your specific vehicle and application.
My Blog
Punch #1586767 09/06/2025 10:30 PM
This is the article from which I learned about this. I would have bolted the pump on and never gave it a second thought. I’ve ordered this “brass baffle” to install. However from what I see corrosion has has eaten away at the cast iron rim to which this disc would be pressed into.
Water pump baffle
Punch #1586768 09/06/2025 11:09 PM
Clean up the cast iron and JBweld that sucker in place. I believe it's in there to reduce slippage behind the vanes of the water pump. Excess clearance behind the vanes would definitely reduce the efficiency of the water pump.
Punch #1586786 09/07/2025 1:51 AM
For future reference, here's the link to the Filling Station offered AF-254 Baffle Plate and a screenshot of the plate below. Thanks for the resource info Pre '68 Dave. smile
~ Dan
Punch #1587066 09/10/2025 9:11 PM
I'd suggest using a ROLOC sanding disc to smooth out the rough casting, and making a thicker brass disc to minimize the clearance to the water pump vanes. Use Devcon epoxy steel or Marine Tex to attach it to the block.
