Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Pre '68 Dave, 55shaker), 110 guests, and 3 robots.
Topics128,277
Posts1,058,453
Members48,490
#1586301 08/31/2025 2:28 AM
FYI:
The replacement bearings they sell on many sites including classicparts.com are seemingly the wrong size or else built to a sloppy spec.
I'm in the rear axle on my '66 burb to replace axle seals and thought new bearings would be a good idea.
That was a mistake, the old ones had about .004" of radial play, but the new ones had .008" !!
Lesson learned:
Keep the old bearings, or else find some new old stock.
New SKFs from Thailand cant beat a 60 year old Hyatt from USA.
'59 Chevy Suburban, NAPCO
Moderator, Electrical Bay
.008" is pretty common from what I've seen. In my case I couldn't use my old ones, though.
~ Jon
Good to know!
A couple of other things I'll mention is that the axle shafts in the 12 bolt rear ends are known for wearing and that plus the looser tolerance in the bearings will add up to more radial play. I realize everyone would prefer something like .001, but I don't believe you can get that without also replacing axles and I don't think .008" is enough to worry about...that being the thickness of two sheets of common copy paper. You'll also have expansion with heat from operation, so usually it all balances. If you were using your Suburban to travel the USA all the time I might be inclined to get new axle shafts but if you're just driving around NM, I think you'll be okay. Once upon a time there were bearings that were made so that they'd run on a different part of the axle (can't recall what they were called) but friends said they thought they were more sizzle than steak.
~ Jon
Jon G - I think your looking for "Axle Saver" bearings. Evidently they can still be found for Chevy 10 and 12 Bolt rear axles, but not sure if these will also work with truck axles??? headscratch
~ Dan
1951 Chevy 3 window 3100
Thanks Dan,
As I recall there were a couple of versions depending on car/truck. A friend or two told me these were okay but just okay.
~ Jon
