| | | Forums66 Topics128,181 Posts1,057,152 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2024 Posts: 89 'Bolter | | 'Bolter Joined: Jan 2024 Posts: 89 | The 1957 3100 truck I am helping with has speedometer issues. It has worked perfectly over the last year. Bear with me please. I think this may be a transmission issue. At very low speed, speedometer jumps, 0 - 60. once you reach speed, i.e. 50 mph, the speedo smooths out. First thought, it was a bad cable, although the installed cable was less than a year old. Replaced cable. Problem remained. Speedo was rebuilt by a very reputable company about a year ago. Took it back to them. They hooked it us to their testing rig, and the speedo functioned perfectly. 0 to 90 was perfect, repeatedly. The speedometer driven gear mounted in the tail housing was replaced about a year ago. it has a steel gear which does not appear to be worn and rotates smoothly. Now to my question. Could the speedometer drive gear, not the driven gear, be slipping on the main shaft? Is it keyed? Could tightening the nut at the end of the main shaft possibly correct this if it is not keyed? Before I drop the driveshaft I thought I would ask for other potential solutions. Nothing has been done to the transmission over the last year. No changes made, etc. The speedometer just started jumping. Thanks for the suggestions and guidance.
1957 3100, 235 with 4 speed floor shift
| | | | | Joined: Sep 2009 Posts: 6,012 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,012 | According to the 1955.2 Series Truck Shop Manual the speedometer drive gear is pressed onto the output shaft u-joint forward yoke. As there is no contradictory information in the 1956 Supplement, I think it's likely that your friends should also be press fit and tightening the yoke securing nut will have no effect if the drive gear is loose/moving on the yoke. A double check of the Master Parts books shows no key for the gear listed.
It is possible that the drive gear could be moving and causing the erratic speedometer function. The only way to know is to drop the drive shaft and remove the yoke to inspect. It's possible that someone could have improperly reinstalled the drive gear to the yoke. The Shop Manual indicates to be sure that the drive gear is installed with the beveled edge towards the front of the transmission. If it was installed backwards it could be improperly seated.
Let us know how you find things when you get into it.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Jan 2024 Posts: 89 'Bolter | | 'Bolter Joined: Jan 2024 Posts: 89 | Excellent explanation! I will pull the yoke and respond accordingly.
Thanks!!!!
