BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
| | Forums66 Topics126,776 Posts1,039,259 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Jul 2025 Posts: 1 Moderated | Moderated Joined: Jul 2025 Posts: 1 | I know I'm not alone when it comes to replacing some widow makers on my 30K all original 66 C60 grain truck. I bought it to haul dirt, but don't have the heart to tear it up. Can some one who's done this share where they got them or what will replace them. Thanks.
| | | | Joined: Jan 2019 Posts: 2,249 Herder of Cats, Goats, and Sheep (moderator) | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,249 | Might I recommend this sticky? | | | | Joined: Jan 2019 Posts: 2,249 Herder of Cats, Goats, and Sheep (moderator) | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,249 | Alternatively, there is a tech tip with info on bolt patterns and such that you can use to cross-reference to newer vehicles. | | | | Joined: Sep 2009 Posts: 4,390 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 4,390 | Welcome to Stovebolt SammyC60!  If you look through the "Big Bolts" forum (where your post landed), you will find a number of discussions about what folks have done to replace their "widow maker" wheels for something safer. While you wait for other "Big Bolt owners to reply with their experience and knowledge, perhaps you'd post in the Welcome Centre and introduce yourself and your truck to the rest of the community. You can tell us how you came by your truck and post some pictures for folks to see in there. Once again - Welcome.  Edit note: Thanks to Fibonachu for getting to the best data to help answer your question!
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | Joined: Aug 2010 Posts: 389 'Bolter | 'Bolter Joined: Aug 2010 Posts: 389 | You'll need to find or have made, a set of longer wheel lug studs. Here's the modern day bling option: https://buytruckwheels.com/products...-aluminum-10x8-75-old-chevy-2-ton-trucksThey also have more affordable steel wheels, https://buytruckwheels.com/products/22-5x6-75-white-steel-10x8-75-old-chevy-2-ton-trucks I bit the bullet and got all six new wheels last year, so my Enterprise won't ever kill a hapless tire tech (or me for that matter) while working on it. The maker says you can go up to 10R22.5", which will also (assuming you've got room in the wheel wells) allow for several hundred fewer revolutions per mile, which means you can go 60mph versus 54mph more comfortably if you still have the original 'slow and slower' split rear axle gear ratio.
Last edited by Gdads51; 08/26/2025 9:06 PM. Reason: remove tracking from 1st web link
| | | | Joined: Mar 2004 Posts: 6,189 'Bolter | 'Bolter Joined: Mar 2004 Posts: 6,189 | SammyC60 didn't say what size tires he currently has. If he has 9.00x20 and he switches to a new 22.5 rim running 10.00x22.5 tires then everything stays the same as those to sizes have the same diameter. Here's the way the 20" and 22.5" tires match up with each other (same diameter). 7.50x20 = 8.25x22.5 8.25x20 = 9.00x22.5 9.00x20 = 10.00x22.5 10.00x20 = 11.00x22.5 11.00x20 = 12.00x22.5 Hope this helps... Mike B  | | | | Joined: Aug 2010 Posts: 389 'Bolter | 'Bolter Joined: Aug 2010 Posts: 389 | 8.25x20" are about 36.5" in height, that's what mine measure out as, and what the specs tend to state. With the stock 6.50:1 these rigs usually came with, that's 3889RPM at 65mph. 900R22.5" spec out at 38.3" in height. So they're a pretty close fit but will give you that 180 fewer RPM per mile. Not a huge difference, but it's not nothin' either. 3706RPM at 65mph. 10.00R22.5" are 40.1" in height so you'll really get a notable difference in RPM per mile. 3540RPM at 65mph. 349RPM difference is a half a mile per gallon, probably.
Also, the wheel vendor above says 10R22.5" tires are the biggest you can use on the 6.75" wheels they sell for 2 ton Chevys.
| | | | Joined: Aug 2010 Posts: 389 'Bolter | 'Bolter Joined: Aug 2010 Posts: 389 | I found a 5.57:1 ring and pinion, so when I get that installed I can run easy to find 900R22.5s and get to 3176RPM at 65mph. That's great, actually. Can hover around 60-65 and keep that big ole' Cadi V8 where it likes to live, with some room to put the hammer down if I need to. The low range would wind up being 7.87:1 or thereabouts, for 50-55mph in low range when climbing a really steep hill. That's a lot less of a hazard on the road than the old 44mph low gear, the 'slower' portion of 'slow and slower' factory final drive ratios.
| | | | Joined: Feb 2004 Posts: 28,674 Kettle Custodian (pot stirrer) | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 28,674 | HMMMMM- - - - -I've got a 1970 472 Cadillac engine and a Turbo 400 trans that's looking for a home. Maybe my 61 American LaFrance pumper truck that's now running a 401 V6 and a direct drive Clark 5 speed? I've also got a Brownie under/direct/over box that can replace the driveshaft mounted fire pump. That one's running 10.00-20 tube type tires on Detroit wheels- - - -not widowmakers. Jerry
