2 members (pdlightning, Tronman), 104 guests, and 3 robots.
Topics128,094
Posts1,056,064
Members48,433
#1585481 08/19/2025 9:48 PM
Moderated
Moderated
I have a generator without any tags or markings (other than those by the posts). How can I tell if it is a 6 volt generator or a 12 volt generator?
1 Offline
I believe that 12vs will have a red part number tag and 6vs will be in black.
Pedals 3
Paddles 0
Except he said "I have a generator without any tags or markings".
1 Offline
Correct, I am sorry
Pedals 3
Paddles 0
Moderator, Electrical Bay
In this case, I would take it to any auto parts store and have them test it for output. Normally they won't charge you to do that.
~ Jon
JayCee - There should be numbers stamped into the side of the generator case that we can use to decode what it is. You may have to do some cleaning to allow for viewing/picture taking. wink
According to a little research through some resource documents, your '54 GMC would have been originally equipped with one of 3 different generators. All are 6 Volt. The original units will have one of these 3 numbers stamped on the generator case:
1100018 = 45 amp 6 volt (Delco Remy offered an "18-U" Rebuilt starter as replacements for this unit)*
1105009 = 40 amp 6 volt (Low cut-in rpm)
1106757 = 55 amp 6 volt
* This unit also listed as standard equipment for Chevrolet trucks of the same year.
Resource info taken from a 1954 AEA Original Equipment Parts Catalog and both GMC and Chevy Master Parts Books
~ Dan
1951 Chevy 3 window 3100
