Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
7 members (niobrarafun, Otto Skorzeny, kades51, Guitplayer, MNSmith, NorCal52Suburban, Bill Hanlon), 562 guests, and 1 robot.
Topics126,778
Posts1,039,291
Members48,100
Most Online2,175
Jul 21st, 2025
Here is a Flywheel that takes a 13" clutch, Casting number 3735858. This came off of a '59 Chevy dump truck with 348 motor. I counted 194 teeth on ring gear. $50 + ship.
Last edited by Gdads51; 08/17/2025 2:21 PM. Reason: remove image marker from text box
Here's a little more detail on chevyb's offered flywheel as it may help decide on a deal for some folks. wink
A search of GMPartswiki using the casting number shows its assigned the part number GM# 3737919. Below is a screen shot of the latest application list I could find there, showing it was used on most 1958-70 Medium Duty Chevy "Big Bolt" trucks (1-1/2 to 2-1/2 ton) with V8's, except trucks equipped with Powermatic automatic transmissions and those having the 427 engine.
There was another listing showing the GM# 3737919 was replaced with a new GM# 3986183 in May 1972. The later GM# shows being used in "big block" equipped Medium Duty trucks as late as 1990.
BTW - chevyb's asking price is down right generous as the later replacement flywheels have asking prices in the $200 - $400+ price range. Get it while the getting is good! thumbs_up
Best of luck with your sale chevyb! grin
~ Dan
1951 Chevy 3 window 3100
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.078s Queries: 16 (0.056s) Memory: 0.5984 MB (Peak: 0.6439 MB) Data Comp: Zlib Server Time: 2025-09-22 17:58:29 UTC
Valid HTML 5 and Valid CSS
