Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
4 members (Gdads51, KEVINSKI, 52Carl, Peggy M), 588 guests, and 1 robot.
Topics126,778
Posts1,039,258
Members48,100
Most Online2,175
Jul 21st, 2025
Here is a never used reproduction front splash panel for 47-53 small trucks. It was painted but never installed and has been sitting in garage for many years . $100 + ship.
Interested. If a 54 has a different grill, would this still fit a 54 3100?
It may bolt on, but its not correct for a 54. It would also look a little wonky where the grille and filler panel fit together.
2 Offline
The 54 Chevy I think uses the same filler panel from 47-53
Judging from online photos of that area
But someone else should confirm on a truck side by side with the two
The 54 gmc definitely uses a new shape filler panel in 54 that is not reproduced
On the Chevy in 54 the new grill with marker lamps appears to stop flush with the lower grille bar to take advantage of the old filler panel
However on the gmc that new chrome grille area around the park lamp extends down behind the bumper so the filler panel definitely has a jog in it to accommodate
I have one 54 filler panel on my farm I was gonna use and then realized that detail
It would fit the Chevy but it had a big gap there
Edit: online parts places often miss label compatibility years
Non of them make that special 54 gmc filler but list it the same as 47-53 gmc incorrectly
-s
K Online: Content
My 54 gmc filler is different .here is a 54 chev filler from one of the vendors
kevinski
1954 GMC 9300
AD Addict & Tinkerer
Dan just posted a sale from two vendors for 54-55 filler panels at less than 50 dollars plus shipping here.
Phil
Project Journals
Stovebolt Gallery Forum
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 1.510s Queries: 16 (1.507s) Memory: 0.6164 MB (Peak: 0.6820 MB) Data Comp: Zlib Server Time: 2025-09-21 23:10:44 UTC
Valid HTML 5 and Valid CSS
