Here is a never used reproduction front splash panel for 47-53 small trucks. It was painted but never installed and has been sitting in garage for many years . $100 + ship.
The 54 Chevy I think uses the same filler panel from 47-53 Judging from online photos of that area But someone else should confirm on a truck side by side with the two
The 54 gmc definitely uses a new shape filler panel in 54 that is not reproduced
On the Chevy in 54 the new grill with marker lamps appears to stop flush with the lower grille bar to take advantage of the old filler panel
However on the gmc that new chrome grille area around the park lamp extends down behind the bumper so the filler panel definitely has a jog in it to accommodate I have one 54 filler panel on my farm I was gonna use and then realized that detail It would fit the Chevy but it had a big gap there
Edit: online parts places often miss label compatibility years Non of them make that special 54 gmc filler but list it the same as 47-53 gmc incorrectly -s
Interested. If a 54 has a different grill, would this still fit a 54 3100?
Dan just posted a sale from two vendors for 54-55 filler panels at less than 50 dollars plus shipping here.
Phil Moderator, The Engine Shop, Interiors and Project Journals
1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc Brakes Project Journals Stovebolt Gallery Forum
