Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
11 members (bucktruck, 2ManyTrucks, fonz8261, Peggy M, wilbur53, Gib70, greenie-reddy, 1942-G506, Lightholder's Dad, 2-Ton, Otto Skorzeny), 586 guests, and 1 robot.
Topics126,776
Posts1,039,258
Members48,100
Most Online2,175
Jul 21st, 2025
GMC king pin set P/N 2251849 1950's vintage 1.110" dia. pin . I think these fit big truck with 7000 lb. front axle like 450 - 470 size trucks $75 + ship
I have found and added 2 more lock pins , see second picture.
chevyb - A little research through some various parts books and sources shows the GM# 2251489 was used in a variety of US and Canadian GMC and Chevrolet "Big Bolts".
I found it listed as fitting a 1958-59 GMC P350 (Heavy Duty 16,000 lb Forward Control Cargo Van Chassis), 1956-57 US Chevrolet Trucks Series 7-8-9-10 (all 2-1/2 ton trucks with Eaton front axles) as well as Canadian Chevy/GMC Series 1700-9700 and Series 1900-9900-W1900-W9900 (all 2-1/2 ton trucks) in just the few ready reference resources I have.
All the GM Parts books indicate its an Eaton# 32427 King Pin set, which also cross references to a TRW K439 replacement set. A TRW K439 reference seems to indicate they also fit "GMC: 1950-54; D450-37, D470-37, DW450-37, F450-37, F470-30, S450-30, HC520-600-650, HCR520-600-620-650, HCS520, HF450-520, HFR520", but I'm unable to confirm that with my resources. Perhaps someone with more GMC Parts Books can add to this info?
The only other item to note is it appears your set is missing 2 of the required 4 locking pins/nuts. This kit requires 2 locking pins for each king pin per my resource info.
Definitely some hard to find parts and hope they can find a new Stovebolt home. Best of luck sir! thumbs_up
~ Dan
1951 Chevy 3 window 3100
Thanks for all that info . I have added 2 more lock pins .
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.054s Queries: 15 (0.051s) Memory: 0.6005 MB (Peak: 0.6528 MB) Data Comp: Zlib Server Time: 2025-09-22 00:29:44 UTC
Valid HTML 5 and Valid CSS
