1 members (stoveboltgator), 218 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#1584302 08/04/2025 7:36 PM
I have a GM 12 bolt 8.875 on my 49 1/2 ton. Current gear ratio is 3.73. Looking to change to 3.90. Does anyone know where to get a truck gear set that is 3.90. I see a lot for cars, but none for trucks.
Professional procrastinator
I am not sure if what I have will work for you. I have a 3.90 ring and pinion set I found in my parts yesterday. If you PM me your email I can send you some pics.
1947.2 GMC 1/2T SWB panel
1947.2 GMC 1/2T long bed
1948 GMC 1/2T short bed
H Online: Content
Is there a good reason for making such a tiny change in ratio? The same difference in engine RPM could be accomplished with a slightly lower profile tire, with a lot less hassle and expense.
3.90 was a ratio wasn't used past '62.
Integral housing axel such as your "12 bolt" don't have much in common with older units.
BC
1960 C60 pasture art
Sir Searchalot
Sir Searchalot
IMO 3:73 is the perfect ratio for acceleration, torque, gas mileage, speed, hiway...it's a compromise.
Put me down for Hotrod's suggestion of slightly lower height tires. An inch lower tire will give you the RPM change you seem to be after.
There is a calculator available online which takes into account RPM, tire height and rear end gear ratio. You plug in what you currently have with your current tire height, then replace your current tire height with shorter tire heights until you end up with the RPM you are looking for.
Thanks. This answers a lot of my questions
