1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#1584269 08/04/2025 12:55 PM
I have a '50 3600 that has a front disk brake conversion. I am planning to replace the current wheel studs (1/2-20) with 9/16-18 thread studs to match my rear wheel studs.
I am wondering is anyone know the details of the original studs (spline diameter/count and length) to provide a starting point for my search for new studs or insight why this is a bad idea.
My alternate plan is to remove one of the existing studs to measure, which I may do before ordering but thought if someone here has information as a starting point it may save some time/effort on my part.
1949/50 3600 Project
Follow in Project Journals
WICruiser - A check of a 1929-53 Chevy Master Parts Book shows your 1950 3600 existing front wheel studs are listed as GM# 3680899. The chart below show the part number and specific dimensions of the wheel stud for you to use in stepping up to a 9/16-18 stud. Hope this helps you find what you want. wink
~ Dan
1951 Chevy 3 window 3100
Gdads51, thank you for this great information. Too bad the chart does not indicate the diameters and spline count as well but this certainly does help. I may even be able to get some GM part numbers for 9/16" studs that would be a good starting point from the information included.
The very last stud listed in that chart is a 9/16-18. Not significantly longer and perhaps adaptable to your need. headscratch
~ Dan
I tried looking at the GM numbers that were 9/16 thread from the chart (including the 5238559) but none of them cross referenced to anything current and I could not find their respective serration diameters.
I removed one of the existing (original) wheel studs and the serration OD is approx. 0.555. It seems that 9/16 threaded studs would not pass through the serration opening.
All of the 9/16 thread studs I can find are 0.625 to 0.655 serration OD so it appears if I am going to pursue this I may need to have the hubs bored slightly to accept a larger serration.
These things are never easy.
I did a little deeper dive in GMPartswiki to see if I could find something more current. I found GM# 3997956 as a front wheel stud, 9/16-18 x 2-1/8" that was used on 1971-90 something 3/4 and 1 ton trucks/van/RVs with front disc brakes. I couldn't locate a serration size for the GM part, but a Dorman 610-181-1 lists as a replacement 9/16-18 x 1-7/8" wheel stud for those vehicles. It does lists a serration size of 0.623".
Either way, if you are wanting to upgrade to the 9/16-18 studs it will require reboring the hub stud holes like you said as they are significantly larger than the original 1/2" studs. Does your disc brake rotor slip over the existing studs onto the hub? If so, those may require reboring too.
~ Dan
Gdads, thank you for the additional research.
I need to talk to my machinist about the potential to have the hub holes machined larger.
The rotors slide over the 1/2" studs onto the hub and I belive the holes are large enough for the 9/16" studs but I need to confirm. I know the existing wheels (rollers) fit over the 9/16" studs I have on the rear as do the wheels I plan to use once I get tires.
I talked to my machinist and ordered some studs that I believe will work out fine. There are a lot of variations of studs available in theory but restricting the selection to those available at a reasonable cost helps trim down the options significantly.
I did some searching on the internet and general concensus seems to be the holes need to be 0.007-0.017 smaller than the measured size of the knurl and reamed (not drilled) but it would be nice to get confirmation from someone with experience.
