6 members (TexasJim50, Hanks custodian, Peggy M, klhansen, Woodcmiami, MickeyP), 90 guests, and 2 robots.
Topics128,059
Posts1,055,818
#1584199 08/03/2025 12:37 PM
What's a good source for rings these days?
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
MikeE #1584200 08/03/2025 12:57 PM
MikeE - You can look through the ones offered by Jim Carter or just do a web search like this. Then take your pic from all the various sellers.
I did see that Chev's of the 40's is showing theirs as "Out of Stock". Even Rock Auto has a few offered and their prices look pretty reasonable.
Or you could post an ad in Truck Parts Wanted in the Swap Meet. Hope this is helpful. smile
~ Dan
1951 Chevy 3 window 3100
MikeE #1584210 08/03/2025 2:59 PM
Thanks Doing this for a friend I am trying to get him on the site.
1946 1-ton Panel
MikeE #1584226 08/03/2025 9:44 PM
There's usually a lot of rings available on Ebay. Any rings for an engine with a 3.5" cylinder bore should work as long as the rings are the right thickness. Make sure you measure the pistons for oversize, and get the right diameter rings to match the pistons- - - - -most 216s have been overhauled and bored at least once in the past 70 years or so.
www.ebay.com/sch/i.html?_nkw=Chevy+216+piston+rings
MikeE #1584350 08/05/2025 3:02 AM
Thanks all. The guy I asked for already got some at3.5. And has already put it back together. Not sure what he’s doing next because he’s waiting for some other parts. He seems to be very knowledgeable about things and doesn’t waste time. Also motivated to get the truck on the road again. He’s also an old tractor guy
1946 1-ton Panel
