| | | Forums66 Topics128,059 Posts1,055,823 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | What's a good source for rings these days?
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Sep 2009 Posts: 5,830 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,830 | MikeE - You can look through the ones offered by Jim Carter or just do a web search like this. Then take your pic from all the various sellers. I did see that Chev's of the 40's is showing theirs as "Out of Stock". Even Rock Auto has a few offered and their prices look pretty reasonable. Or you could post an ad in Truck Parts Wanted in the Swap Meet. Hope this is helpful.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | Thanks Doing this for a friend I am trying to get him on the site.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Feb 2004 Posts: 29,774 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,774 | There's usually a lot of rings available on Ebay. Any rings for an engine with a 3.5" cylinder bore should work as long as the rings are the right thickness. Make sure you measure the pistons for oversize, and get the right diameter rings to match the pistons- - - - -most 216s have been overhauled and bored at least once in the past 70 years or so. www.ebay.com/sch/i.html?_nkw=Chevy+216+piston+ringsJerry
| | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | Thanks all. The guy I asked for already got some at3.5. And has already put it back together. Not sure what he’s doing next because he’s waiting for some other parts. He seems to be very knowledgeable about things and doesn’t waste time. Also motivated to get the truck on the road again. He’s also an old tractor guy
