I am tacking the upper roof filler. Also the pillar frame ..covers? Getting the windshield flange together. So I can put the windshield back in and doors on. These pics are from 2 years ago. Getting the rusted out filler was hard. It was quite the horror. I riveted the filler to the roof flange. That brought the filler up tight. I am now drilling those out one at a time and spot welding. Dan Timm drove by this morning and we got my gas welder running. Can`t be stopped now. I`ll take some pics when I get it primered.
~ BD. "You won't find me in an old folks home" Pioneer Florida Cracker 1958 Apache Stepside 1958 Apache 1/2 ton Panel 1959 Apache 1/2 ton Panel
Holy crap!! The doors are on and fit perfect. I guess both lucky and good. They open and close like brand new. After a new floor,+ new A pillars married to the old. Everything stayed true. Today is the first day the finished doors/glass and rubber were put on. I am astounded. Now I can finish suring up the "A" pillars and move to the fenders. Need the windshield put in. I have the original old glass with rubber on. I need to find someone who has done it before.
Looking good! You’ve have come a long way! Great job!
Phil Moderator, The Engine Shop, Interiors and Project Journals
1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc Brakes Project Journals Stovebolt Gallery Forum
Thanks guys, Here is the first part of this truck. Somehow it got mixed up when moderators organized my postings. So the first part of the 59 is really the 58. Never braced anything. Just go slow. Take measurements and use a level. Its not that hard . Leave as much original as possible.
~ Dan 1951 Chevy 3 window 3100 Follow this story in the DITY Gallery "My Grandpa Carl's Truck and How it Became Mine" 1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
Boys I said, above the canyon wall, Strong eyes did glow.
Great White Buffalo? Looking really good. Hats off to your perseverance and determination. It's going to look fantastic. I can hear Ted in the background!
1947.2 GMC 1/2T SWB panel 1947.2 GMC 1/2T long bed 1948 GMC 1/2T short bed
10-4 - If not for The Stovebolt I'd be no where with all this. I could not find anyone that could work on the engines or do any mechanical work on the trucks. Or just did not want to.
So here I am, busted knuckles and all. Little bit of luck, skill and smarts. Time and the whereforall too. My absolute next thing I need help with is installing the windshield. I rescued the original and have it sitting here with the rubber on. From what I can tell that's a 2 +3 man job.
Here is the truck when I picked it up. You can see the tree limb hit to the roof edge. I did my best to get the dent out.
Buddy, There is an existing TF Windshield Tech Tip with some possibly helpful "one-person" instructions. Not saying it won't go better with help, but if help is not available it is doable. Will be watching and see how the reinstall goes. Best of luck!
The key thing from reading that is omitted. How does 1 man pick the windshield up and set it in the truck? I see the process after its in. thanks Dan!!
A set of Suction cup lifters to use for handles helps with that. If the hood is on, you could slide the glass over that (covered by a blanket) with the inside facing up, and then tilt it up into the opening.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
My gosh Kevin, that is a method! I would be scared it would crack. The thing is I have 2 to do. My 59 panel windshield has always had a crack in it. I`d like to take care of both at the same time. With the 59`s windshield out, I want to clean and repair/ paint that mounting flange. There is a fella ,young guy who does it around here. But he acts kinda untouchable as I had set up an appointment with him at a local car dealership and he never showed. He was gonna charge $450 and not guarantee if the WS would break. So you kinda get a sense of whats around me and why if you want something done, I`ve learned to do it myself. I used to own and operate a 300 acre farm. I have that experience. But doing something twice or incorrect in this job has less forgiveness. Time and money. It has come a long way
You'd be surprised how strong glass is. As long as you don't smack it with something sharp you could probably pick it up in the very middle with both ends hanging free and not have it break.
I though my truck was a Fred Flinstone truck. Your floor was completely gone. Mine just had a few holes. That's awesome that you got if back in shape.
Ive been lucky. No glitches really. Everything went together smoothly. The hood... I sure would like to have that drivers side hinge section to be able to use the original. I also need a single headlamp bucket.
Thanks. As soon as I finish throwing mild steel at this "A" pillar to sure it up and the firewall to floor. I`ll move forward still with the fenders. Luckily what I`ve been welding cannot be seen eventually. man thats ugly but fingers crossed , will be solid. Far as hoods. I am hood rich. I have noticed and others may say, but I noticed this 58 panel is made of more "stouter" metal than the 59 panel. The 58 feels like a tank when I strike it and metal is solid. The 59 is too but not the same. I`d like to repair the original hood.
I have the three repair panels for the rear. The first will be long to fit The wheel well panel is a good fit and the third panel will be short and a sheet will have to be added to reach the rear corner. How would you guys who have done this before ,go about affixing the panels? In what order? Wheel well first? Or consider rear to front> IDK. won`t be long I`ll be thinking about how to go about it. The repair panels are for a 1960-66 fleetside.
Billy, how did that go? Did you have some help with it?
~ Peggy M 1949 Chevrolet 3804 "Charlie" - The Stovebolt Flagship In the Gallery "We make a living by what we get; we make a life by what we give." -- Winston Churchill
Went well. Took a very short time. Dan Timm stopped in this morning to help me. Lines are very good. I may need a hood hinge. Using the originals. One seems better than the other.
'Splain that one a litte for the folks who can't get the YT vid. What are you looking for??? Thanks.
About 2 extra set of arms to install the windshield . I was able to salvage the original windshield and have the rubber on. I might be able to send that video to my neighbor and he and I could attempt it. The person alone method might work for me. If I can find willing help ,I should use it as this is a fairly expensive piece of glass.
I`ll let a cool secret out. Being very proficient with a bow, I had not used or needed my foam target shot stopper. But the use is not lost. It has to be the best seat to use to work on just about anything. I use to weld and work on my trucks. It has three different heights,16x 18x11 very comfortable and indestructible. Kick into place. I have ordered a new one for this years prehunt. They are about $45.
