4 members (Rich'sToys, Hotrod Lincoln, TooMany2count, 1 invisible), 130 guests, and 6 robots.
Topics128,021
Posts1,055,354
Members48,420
#1583365 07/24/2025 12:23 AM
Is there a minimum recommended engine-to-firewall clearance? I have the 235 sitting in my '36, and it's pretty darn close to the firewall in the back. There's a little bit of clearance but not much. I could probably cheat the engine forward slightly if need be.
Ron
Sir Searchalot
Sir Searchalot
Your thumb
Originally Posted by bartamos
Your thumb
Is that the official spec? smile
What if you have a metric thumb?
Sir Searchalot
Sir Searchalot
Your thumb
It is very accurate for motor to firewall clearance. Just like torque a bolt til your elbow clicks. Works with SAE or Metric. There's no guess work in automobile mechanix. This info is dependent on whether you are fasting or not.
RBs36 #1583387 07/24/2025 11:16 AM
In all seriousness, I don't know how much these motors move under torque, or as motor mounts wear. I'll just slide it forward 1/4 or 1/2 inch. Can't go too far, though for fan clearance, plus using stock pedals.
RBs36 #1583389 07/24/2025 12:13 PM
The engine movement under torque is basically side to side rather than fore to aft so if you have clearance it should be good. That being said it is a balance between rear clearanc and fan clearance and I prefer to have more fan clearance so tend to bias toward the rear.
1949/50 3600 Project
Follow in Project Journals
fore and aft are only used in nautical terms. I don`t get why they are used here.
My dad was a Coast Guard Flotilla Commander and would never use those words out of context.
Just sayin
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
U
U Offline
Thanks for the laughs you guys! 😂
~ John in Utah
Here We Go
Follow in his DITY Bay
We were doing so well and then WICruiser has to come in and give a good straight answer.
H Online: Content
I bolt the engine down on the mounts and chain a 6 foot long pry bar to the engine. I give it a HARD pull toward the passenger's side. If the engine doesn't touch the firewall, it's good to go. Torque reaction is always toward the passenger's side. Sometimes a little BFH massage to the firewall sheet metal at the closest point of contact is all that's needed.
Sir Searchalot
Sir Searchalot
There is some "force" on acceleration. Force on the motor mount rubber. The force is called momentum or weight transfer. 1/2" clearance is a good minimum. It is usually the distributor that is close. Then the valve covers.
Yes, the side to side is what I'm concerned with. The passenger side is close on the corner. Can't move the engine over very much but sliding it forward will give a little bit more clearance around the curve. Maybe I can get a slight bit of lateral movement too.
Jerry, good tip. I'll give that a try. BFH may be necessary. But I guess if it needs more clearance, the engine will make it on it's own. LOL grin
Unless you plan on pulling stumps, I doubt that a 235 engine will move enough to hit anything where it is located in your pic.
If it does, it will leave a mark to indicate where to hit it with a hammer or pry the metal down with a log crowbar.
My ‘37 with original 216 is pretty tight. The problem you’ll have with the 235 will be the radiator clearance.
Larry
Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
Larry, that's why I can't really go forward much. I bought the plate from Pre-68 Dave to use the earlier water pump. Even with that I'll likely have less then .75" of clearance. Probably closer to .5"
AD Addict & Tinkerer
Keep in mind, you need enough clearance to change the fan belt.
Phil
Project Journals
Stovebolt Gallery Forum
Yes, very important point Phil. thumbs_up
