| | | Forums66 Topics128,090 Posts1,056,022 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2014 Posts: 305 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 305 | A couple years ago i bought all new brake hoses for my coe off ebay. I was putting the truck away for the winter and the brakes where sticking on the back axle. So i just got to check it out. I was looking at the brake hose and wondering if it could be swelled shut. I noticed that the hose was like a wet noodle and and it looked like it was sweating. It had a bunch of little dots like the brake fluid was weeping through the hose. I looked at the front and 1 of those was the same. I changed them all. The hoses said made in argentina also said dot. Probably some inferior hose. Im just glad they didn’t blow out . Any how I replaced the hoses and the brakes don’t seem to be sticking now. Hopefully that was the problem time will tell | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Wow, That's scary. Glad you got it figured out before you took it out on the road. | | | | | Joined: Feb 2010 Posts: 476 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 476 | Had the same issue with my rear brakes not releasing, replaced the wheel cyl. on one side only to find out the rear hose was plugged | | |
