| | | Forums66 Topics128,266 Posts1,058,367 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 284 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 284 | This is a mig welder from harbor freight. Has any one bought one and how good are they. I don't want a flux core welder I want one that uses gas and this one is both. Any imput would be great. My mini mig that I've had over 20 years just crapped out. I don't have a lot of money to spend and yes I know you get what you pay for. http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=55250 | | | | | Joined: Jul 2005 Posts: 308 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 308 | The thing to remember is you normaly get what you pay for,If you don't care if when it breaks that finding parts may be an issue than it should be ok, if not you may want to look at HD, lowes or other places that have more name brand welders.
Ed | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | dad6timz,
I can't vouch for the quality of this welder, I will merely say this. Make sure you actually see the guts of the machine to verify that it truly does have a gas valve and will operate with shielding gas.
I have seen Harbor Freight advertise incorrectly.
Gun liners and contact tips are thought of as consumables...make sure you can find these items to fit your welder. Without them, it is a table with wheels.
With Harbor Freights liberal return policy, I would certainly give this welder a road test!
Stuart | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Maybe the liberal return policy doesn't apply to "Factory Reconditioned" items...if this were the case, I would get religion, as robin58 did, and shop elsewhere.
Stuart | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I have one, it has been thru 2 rolls of wire w/no troubles, yes it will operate w/gas but you have to buy a regulator($35). yes it is a cheap welder, but I cannot afford a real one. I paid $40 for mine, it was a returned unit that did not feed wire-it had a piece of wire broken off inside the liner, once removed it has worked fine. brian | | | | | Joined: Mar 2005 Posts: 284 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 284 | Thanks for the imput but after messing around with my old one it now works. I now get to spent the money on an exhaust system for my truck. Money better spent for sure. | | | | | Joined: Jun 2004 Posts: 73 Member | | Member Joined: Jun 2004 Posts: 73 | I bought a recon clarke off ebay last year, its a dual mig, for less that 150. That thing penetrates like crazy, really easy to use and has been a workhorse. We weld some beefy stuff on our project truck. Anyway just two cents on the subject. | | | | | Joined: Aug 2006 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 26 | The problem most people have with a wire feed welder is the "feed" part. You have to make sure that the spool can rotate freely-but not too freely. Also ensure that the drive rollers are adjusted correctly. If you have machine that uses plastic drive rollers (most all do) you should keep spares with you replacement tips as these are consumables as well.
I ditched my 220 lincoln mig for a clarke. The clarke better handles the heavier work where the lincoln preferred the light welding. | | | | | Joined: Aug 2006 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 26 | Oh, I started shopping for the replacement because I tired of replacing the plastic drive wheels in the Lincoln. Welded every day and the roller might have lasted a few weeks. | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | My century 125 GL has steel feed wheels. It only acted up once, when the wire birdnested before I knew what was going on and caused the welder to shutdown. Removed the nest and the thing was fine.
My migs only draw back is that sometimes the inner spiral liner shifts and will make those birdnests and then I have to take it apart and reset it. Other than that, its great.
If money grew on trees, well, I'd replace it.
Anyone had any experience with the HTP rigs? they look impressive enough... | | |
