Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
5 members (KDrown, Woodcmiami, PaulH, EchoBravoSierra, Otto Skorzeny), 545 guests, and 1 robot.
Topics126,776
Posts1,039,259
Members48,100
Most Online2,175
Jul 21st, 2025
Looking for a transmission mount for a 1952 Chevy 1/2 ton . Picture of mount attached. Thanks.
Mike - Chev's of the 40's offers Transmission Mount Item # 3688234 48-53 and says "In Stock". Classic Industries lists Item# 14092 as "Arriving Soon".
One of these work for you, or are you looking for a used original? Best of luck in your search! thumbs_up
~ Dan
1951 Chevy 3 window 3100
Professional procrastinator
Mike, Have you found this part?
1947.2 GMC 1/2T SWB panel
1947.2 GMC 1/2T long bed
1948 GMC 1/2T short bed
Interesting that I dug mine out of storage today and found out that the polyurethane resin I used to re-restore it last October had sagged pretty bad (see pic) and needs to be redone AGAIN! frown They say the third time is the charm. ohwell
If you have one that the rubber has gone bad on, they can be repaired. Shoot me a PM if you'd like some info on doing that. Cheaper than buying a new one (assuming you can get the right stuff to revulcanize it.)
Last edited by klhansen; 08/07/2025 10:48 PM. Reason: added pic. Where's that flat forehead emoji?
These are not from 1952 but from a 1948 which I rebuilt
Mike, Let us know if you found one or still looking.
Craig
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.120s Queries: 17 (0.024s) Memory: 0.6173 MB (Peak: 0.6837 MB) Data Comp: Zlib Server Time: 2025-09-22 01:53:10 UTC
Valid HTML 5 and Valid CSS
