4 members (Shardean, Tstan7, 2 invisible),
94
Mod | | | Forums66 Topics128,022 Posts1,055,353 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#15823 11/14/2003 4:30 PM | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | Does anyone know a source for the shorter bushing that goes in the steering box cover on an AD? The shop manual says to just replace the cover if the bushing is worn since the bushing is not a service part, but good luck finding a new cover. I thought about cutting down the longer bushing that goes in the steering box itself, but figured I'd ask here first. | | |
#15824 11/14/2003 6:03 PM | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | You know, I had the same problem, and I tried exactly what you are discussing. Then I found that the sector shaft would not fit into the new bushing. I ended up getting a cover off a junker, it was a pretty good fit. But I was stuck, and had no other options that I could see. | | |
#15825 11/14/2003 7:35 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You can ream the bushing with a brake cylinder hone for a selective fit if you need to. I had to do that with the Ross Cam & Lever steering box on my Jeep.
#15826 11/15/2003 3:12 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Could somebody explain why there are two bushings in some of the kits, like the one from Chev's of the 40s ? Is one for the cover or what? | | |
#15827 11/15/2003 7:07 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Now I see in the manual that there are two bushings in the main housing, for the sector shaft. I think you can buy the bushings separately from the kit. I wonder if one bushing could be cut to length and used for the cover bushing. I am just about to take mine apart. | | |
#15828 11/18/2003 1:21 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I have taken my steering box apart and there is one bushing in the housing and one in the cover. the Chev manual states that the cover should be replaced if the cover bushing is worn. The GMC manual talks about removing it using a tap to pull it out. It then goes on to say the that after the new bushing is inserted in the cover, it will need to be bored. It also says that the bushing in the housing does not need to be reamed after installation. I would really like to understand what is going on here. | | |
#15829 11/18/2003 1:33 AM | Joined: Sep 2002 Posts: 158 knuckle head | | knuckle head Joined: Sep 2002 Posts: 158 | I replaced both bushings,they were NOS GM parts.I then took the housing and cover to a friendly machinist who lined honed the smaller bushing from the center line of the larger one, insuring the best fit possible. | | |
#15830 11/18/2003 1:37 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Rust Bucket, thanks, and now it makes sense. The smaller bushing is sized to be line honed when lined up with the rest of the housing.
Oh another little tid bit: I was talking to a rebuilder a while ago. He was explaining to me why he charges so much money to rebuild one. He told me that sometimes when there is a little wear on the shaft, he will chrome the end some to bring the size up a bit. Neat trick I think. | | |
#15831 11/18/2003 2:50 AM | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | Rust Bucket, did you find the shorter bushing or did you cut down the longer bushing from the housing? | | |
#15832 11/18/2003 3:07 AM | Joined: Sep 2002 Posts: 158 knuckle head | | knuckle head Joined: Sep 2002 Posts: 158 | It was a shorter bushing, I bought them from Obsolete Chevy 10 years ago.If you only have to remove a small amount of material, the brake hone job suggested by Four on the Floor should work if you're patient. | | |
