4 members (Jon G, Gray_Ghost, Bill Hanlon, MRMEROTH11), 85 guests, and 0 robots.
Topics128,068
Posts1,055,881
Members48,428
#1581110 06/28/2025 9:57 AM
Has anyone got that small baffle which attaches to the crankcase near the road draft tube?
BroB #1581161 06/28/2025 11:19 PM
By any chance does that a 216 have two small baffle screws in block behind gen. 2 screw 6” apart.
Edited by moderator
All 216s and 235s have those screws, but they're on the passenger's side, not behind the generator. They hold a sheet metal deflector in place below the road draft tube to keep oil from being splashed up into the draft tube by the crankshaft. There's a 3-screw sheet metal plate on the driver's side, called an "oil distributor" that meters oil through a copper tube to the rocker arm shaft.
Jerry, Punch is asking about a draft/oil filler tube baffle for his "207", which he has posted about elsewhere here and in the Swap Meet.
Punch, The 216/235/261 baffles regardless of year won't fit your "207". You need to find a 207 donor unless you figure out a way to fabricate a replacement deflector.
~ Dan
1951 Chevy 3 window 3100
The baffle plate needed is p/n 837998 (as posted by Dan in the Parts Wanted Ad). 1936 was the first year for the Baffle so it's a one year only part, If my memory is correct it was held in place by (2) 1/4-20 round head machine screws with nuts. One is located behind the Gen and the other just above the dip stick.
Here's a cutaway drawing showing the Baffle from "Chevrolet Six Car and Truck, by Page' ".
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Excellent info and much appreciated. My truck is definitely a 1935. The description of the two mounting bolts is exactly right with a spacing of approximately 6”. Nice job.
Punch, what's the casting number on your Block? It's not uncommon to have a 1936 block in a 1935 as the 35's were prone to overheating as the water jacket didn't cover the drivers side of the cylinder jugs...they fixed that for the '36 model year and from then on used the '36 as the replacement for the '35. The '35 block didn't have the baffle plate.
1935 Block = 837591
1936 Block = 836010
My info is based on US made parts...Canadian might be different???
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
GM J298
836010
Did the term “numbers matching “ apply 90 years ago because my metal plate on firewall has a different number than the block?
Your engine was probably replaced.
1950 Chevrolet 3100 (Ol' Roy)
Very likely. Thanks
Punch - Your block date casting code "J298" decodes as J = October, 28 = 28th day, 8 = 1938, if the Canadian casting date codes match with US code info. The later casting date could (maybe) mean it is a replacement engine as we have found in some later year engines. Perhaps someone with more knowledge of the earlier engines has some info that might confirm or refute this info?
I can't find anywhere in your previous posts on what the engine serial number is??? Can you post more pics of your engine so we can try and better ID it?
~ Dan
1935 truck with 1938 engine. You're movin' on up!
It's actually a 1936 block that was cast in 1938 as a replacement (a 1938 engine would be a 216). The machined surface in his picture is missing a serial number, meaning the mechanic that replaced his engine didn't transfer the original engine number over to the replacement block (very common oversight).
The engine serial numbers and the body serial numbers were never the same.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Does anyone know of any “dead” 207 blocks that I can get an oil baffle out of?
Why not just make one? It's nothing but a piece of sheet metal.
Have already started working on it. But still prefer proper one in case my design is flawed.
