6 members (TexasJim50, 1955 1 Series, stlcardinalsguy, 2-Ton, Oswald, cmayna), 73 guests, and 4 robots.
Topics128,180
Posts1,057,157
Members48,464
So...my dad bought this pickup in '54 and I have had it for over 30 years. I have done allot but mostly just kinda cleaned it up and here is the most recent project! I'm installing a S.Co.T blower with Holley 142 internals, fed by big bore Stromberg 97s on the original 235. The four speed is still in it but I did attach a Gear Vendors unit which was awesome. More pictures to come if anyone is interested.
Wow, don't see that everyday! Very cool.
Those carbs may be a bit small
The air filters are a bit small, a single filter for both is probably better.
1 Online: Sleepy
Not something you see very often. Thank you for showing us your setup. V8's aren't always necessary for the old trucks to stay up with traffic.
AD Addict & Tinkerer
How does it run with such restrictive ports in the head?
Also we would love to see more pictures!
Phil
Updated to: ā€˜59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc Brakes
Project Journals
Stovebolt Gallery Forum
RLB Offline
I’m interested in more photos. Very cool project.
1966 C-10 Short Stepside
HiPo
Step-by-step ~ and on-going resto build
in the Project Journals
They put a Paxton blower on Hornet inline six flatheads in order to keep up with flathead V8s. I'm pretty sure stock inline six flatheads don't breathe very well. From what I've read, those Hornets did well on circle tracks back in the day.
Forced induction will make up for lack of breathing to some extent on any engine. You then just have to worry about if the rest of the engine parts don't come out the sides or through the oil pan. smile
Carl, I agree. A day with a carbide burr will go a long way on these old heads. Some say it doesn't matter just cram more air in it. The Physicist in me says it matters even more because your moving more air and the restrictions will compound. More boost with less flow means higher intake air temperatures the enemy of boost. JMHO.
Last edited by Peggy M; 06/30/2025 10:07 PM. Reason: remove quote; not necessary ;)
Mick,
The Physicist in you makes a valid point.
Too much boost is bad, but a little bit, such as the amount of boost that a Paxon blower installed on an inline 6 Hornet produces, sure seemed to work.
"A man needs to know his limitations."
I used to read about the 'Unbeatable, unbreakable Hudson Hornet six" in old hot rod magazines. Apparently it was a pretty sturdy old engine that cleaned house on the oval track back in the day.
Tronman - Hudson's "dual H" (dual carb) engine helped along by the Hudson's low center of gravity .
O Online: Content
Twin H-Power!
1950 Chevrolet 3100 (Ol' Roy)
Before my time, but so cool nonetheless!
The carbs a large body Stromberg 97s. The original 97s flowed...if I'm correct...150 cfm, the ones I'm using are 250 CFM each. I believe the 500 cfm combined will be enough. I'm not trying to spin the world with this set up. I will let you know how it all works out.
Thanks...just waiting on the new timing cover to show and then back to the fun alignment issues.
Thanks...hoping it will cooler once it is back together!
My ride would struggle at 45 mph and then I installed a gearvendors unit in it....could not find a 50s era rearend that had the high-low option, so that is what I did. Now it rolls comfortably and once the blower is done, I will install the eight lug disc brake set up that I just got in.
More pictures to come!
