4 members (WICruiser, Jon G, stlcardinalsguy, Ponchogl), 363 guests, and 5 robots.
Topics128,163
Posts1,057,044
Members48,463
I need a source for air brake tanks for my 72 C60. If you know one please post it.
Nothing special about a air tanks, you can grab them off of just about anything in the junk yard and make it work...
Do a Google or Amazon search if you want new.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
lcfman - A little searching through Chevy Parts books shows the original air reservoir tanks where listed as GM# 2463013 and where used in 1965-73 Chevy trucks equipped with air tanks. Some single tank and some double tank systems depending on the model number. There is also a later 1984 Chevy School Bus catalog that lists the same part number in use on school buses at least up through 1983. Sounds like lots of possible source trucks to try and find a suitable original tank for your truck.
Here's one source that lists a lot of C50/C60 series trucks over this time period and might have what you are looking for. C&H Truck Parts is located in Sioux City, NE.
~ Dan
1951 Chevy 3 window 3100
7
7 Offline
I would buy a new tank, probably most old tanks will have pin holes from sitting with water in them. Search the web for class 8 new truck parts.
I concur with just finding a new tank. Airbrake systems operate at 80-120 psi, so having a new tank that is rated at those pressures and not worrying about it being a potential bomb would be best.
A semi truck service shop should be able to know of a generic replacement tank they can get for you.
1959 Canadian GMC 9600 with a dump box
Intro / Details in Big Bolts
